Doppler effect star and earth question
In summary, the conversation discusses the topic of determining the speed of a star based on the change in wavelength of light emitted by the star. The wavelength of the light measured on Earth is 661.1 nm, while the emitted wavelength is 659.7 nm. By using the formula velocity = wavelength * frequency, it can be determined that the star is moving away from Earth. However, there is confusion about how to calculate the frequency and the units involved, and it is suggested to use the equation for the change in frequency of a wave based on its speed and the speed of the emitter. It is also mentioned that the speed of light is about 300*10^6m/s.
valueduser
Hello I have a question that is giving me trouble:
Light of wavelength 659.7 nm is emitted by a star. The wavelength of this light as measured on Earth is 661.1 nm.
How fast is the star moving with respect to Earth? km/s
Is it moving toward Earth or away from it?
Here's where I'm at. I have reasoned that since the wavelength is increasing that the star is moving away. My main problem is determining the frequency of the light. I assume that I can use the formula:
however the frequency I get just seems wrong. The units are throwing me off too, any help would be greatly appreciated.
What is the equation for the change in frequency of a wave based on its speed and the speed of the emitter? And keep in mind that the speed of light is about 300*10^6m/s (check this before using it, though), so that gives you a way to convert between frequency and wavelength.
EDIT -- Fixed typo in speed of light. It's 300*10^6, not *10^8. Sorry.
Hello there,
The Doppler effect is a phenomenon that occurs when there is relative motion between a source of waves (in this case, the star) and an observer (Earth). When the source is moving towards the observer, the wavelength of the waves appears shorter, resulting in a higher frequency. Conversely, when the source is moving away, the wavelength appears longer and the frequency decreases.
In this scenario, we know that the observed wavelength of the light is longer than the emitted wavelength, which means the star is moving away from Earth. To determine its speed, we can use the formula you mentioned: velocity = wavelength * frequency. However, we need to first find the frequency of the light.
To do this, we can use the relationship between frequency and wavelength: frequency = speed of light / wavelength. The speed of light is a constant value of 3*10^8 m/s. Converting the given wavelengths to meters (659.7 nm = 6.597*10^-7 m and 661.1 nm = 6.611*10^-7 m), we can plug these values into the formula to get the frequency of the emitted light as 4.553*10^14 Hz.
Now, we can use the formula velocity = wavelength * frequency to find the speed of the star. Plugging in the values for the observed wavelength (6.611*10^-7 m) and the calculated frequency (4.553*10^14 Hz), we get a speed of 2.999*10^5 m/s or approximately 299.9 km/s.
In summary, the star is moving away from Earth at a speed of 299.9 km/s. I hope this helps clarify any confusion you had. Keep in mind that the Doppler effect can also be observed in other types of waves, such as sound waves, and is an important concept in many fields of science. Keep exploring and learning!
FAQ: Doppler effect star and earth question
1. What is the Doppler effect?
The Doppler effect is a phenomenon in which the perceived frequency of a wave changes when there is relative motion between the source of the wave and the observer. This effect can be observed in sound waves, light waves, and other types of waves.
2. How does the Doppler effect apply to stars and Earth?
The Doppler effect can be observed in the light emitted by stars as it travels through space and reaches Earth. The motion of Earth and the star relative to each other causes a shift in the frequency of the light, which can provide information about the star's movement and velocity.
3. What is the difference between a redshift and blueshift in the context of the Doppler effect?
A redshift refers to a shift towards longer wavelengths, or lower frequencies, of light, while a blueshift refers to a shift towards shorter wavelengths, or higher frequencies. In the context of the Doppler effect, a redshift indicates that the source of the wave is moving away from the observer, while a blueshift indicates that the source is moving towards the observer.
4. How does the Doppler effect help scientists understand the movement of stars?
By observing the redshift or blueshift in the light emitted by a star, scientists can determine its velocity and direction of movement. This information can then be used to study the motion of stars within galaxies, the expansion of the universe, and other phenomena.
5. Can the Doppler effect be observed in other types of waves besides light?
Yes, the Doppler effect can be observed in any type of wave, including sound waves, water waves, and even seismic waves. In fact, the Doppler effect was first discovered in relation to sound waves, as observed in the changing pitch of a siren as a vehicle passes by.
