Doppler Shift: Communication from a Space Probe
In summary: So if one side has m/s, then the other side must also have m/s, and so on.Yes, your answer has the right magnitude, but the direction is wrong, because of the mistake in algebra. It's traveling towards you, not away from you.
blue_lilly
36
Space probes communicate with controllers on Earth using radio waves. Suppose a probe has a radio-transmitter that operates at a frequency of 516.0 MHz when at rest relative to the observer. This probe is now wandering the solar system. The signal you pick up from the probe is shifted 5.955E+4 Hz higher in frequency than the rest frequency given above. How fast is the probe traveling and is it traveling towards or away from Earth? (assume it is either traveling directly towards or directly away from Earth. You must get both answers correct at the same time.)
c=3E8
ƒobserved = ƒsourse (1 [itex]\pm[/itex] (rel Velocity/c))
I know that this is a one way Doppler Shift, I am the observer and the source is the probe. Because it a Doppler Shift I am going to use this formula, ƒobserved=ƒsourse(1[itex]\pm[/itex](rel V/c))
ƒo = ƒs(1[itex]\pm[/itex](rel V/c))
ƒs: I am given the ƒs in MHz so I need to convert to Hz.
516MHz = 516000000Hz = 5.16E8Hz​
ƒo: In the problem, it says "The signal you pick up from the probe is shifted 5.955E+4Hz (59550Hz) higher in frequency". This means that the ƒrequency that is obsorbed is the ƒrequency of the source plus the amount it is shifted.
ƒo = ƒs + shift
ƒo = 516000000Hz + 59550Hz = 516059550Hz = 5.1605955E8Hz​
c: The speed of light is 3E8.
relV: We are solving for this.
ƒo = ƒs(1[itex]\pm[/itex](relV /c))
516059550Hz = 516000000Hz (1-( relV / 3E8 ))
59550Hz = 1-( relV / 3E8 )
59549Hz = relV / 3E8
(59549Hz)(3E8) = relV
relV = 1.78647E13 m/s
So the relV is 1.78647E13 m/s and the direction would be towards Earth because the ƒo is louder then the ƒs.
But the answer is incorrect and I am not sure what I did wrong.
Any help would be GREATLY appreciated.
How can anything travel faster than light? 1.78647E13 m/s is a huge number.
I think you simply did an arithmetic mistake in step 3 of solving for relV. You would have caught this had you put in all the units.
Lastly, a frequency isn't "louder" than another frequency. It is simply higher or lower.
Likes 1 person
Check the algebra in this step:
As paisiello2 says, you should carry units along in your calculations, to help you catch mistakes like this...
Likes 1 person
I keep trying to fix the carry over numbers but its not working very well, so sorry if it looks really confusing.
ƒo = ƒs(1±(relV /c))
-516000000Hz -516000000Hz
-1 -1 [subtract 1 from both sides]
59549Hz = - (relV / 3E8)
x(3E8) x(3E8) [multiply both sides by 3E8]
(59549Hz)(3E8) = -relV
-relV = (59549Hz)(3E8)
relV = -1.78647E13 m/s [reverse neg sign]
I rewrote the problem in my note book and the answer is still wrong. Am I not seeing the algebra mistake?
The algebra mistake is still here:
The units error is that you have Hz on the LHS of the equation, and the RHS is unitless.
That's because you subtracted 516000000Hz from both sides, instead of...
Likes 1 person
Does this fix the unit error? 516059550Hz = 516000000Hz (1-( relV / 3E8m/s^2 ))
Instead of subtracting 516000000Hz, should I have added 516000000Hz to both sides?
Nope.
If you want to solve this equation: 15x = 30
What do you do to isolate x? You certainly don't subtract 15 from both sides... :smile:
Likes 1 person
Nope.
ohhh, i feel like an idiot
/516000000Hz /516000000Hz
1.000115407Hz = 1-( relV / 3E8m/s^2 )
1.154067E-4 = - relV / 3E8m/s^2
x(3E8m/s^2) x(3E8m/s^2)
(1.154067E-4)(3E8m/s^2)
34622.09 = - relV
- relV = 34622.09
relV = - 34622.09 m/s^2
SO does this look right then? Also would the neg sign mean that it is traveling away from you?
1.000115407[STRIKE]Hz[/STRIKE] = 1-( relV / 3E8m/s[STRIKE]^2[/STRIKE] )
1.154067E-4 = - relV / 3E8m/s[STRIKE]^2[/STRIKE]
x(3E8m/s[STRIKE]^2[/STRIKE]) x(3E8m/s[STRIKE]^2[/STRIKE])
(1.154067E-4)(3E8m/s[STRIKE]^2[/STRIKE])=34622.09 = - relV
- relV = 34622.09
relV = - 34622.09 m/s[STRIKE]^2[/STRIKE]
Closer. The units are not correct, though. See my edits above...
The units of velocity are m/s, not m/s^2. And when you divided Hz/Hz in the first step, that makes the LHS dimensionless, just like the RHS. The units of the LHS and RHS of any equation have to match.
Related to Doppler Shift: Communication from a Space Probe
1. What is Doppler shift?
Doppler shift is the change in frequency of a wave due to the relative motion between the source of the wave and the observer.
2. How does Doppler shift affect communication from a space probe?
When a space probe is moving away from Earth, the frequency of the radio waves it transmits will decrease, causing a redshift. When it is moving towards Earth, the frequency will increase, causing a blueshift. This can affect the accuracy and reliability of the communication signal.
3. Why is Doppler shift important in space communication?
Doppler shift is important in space communication because it allows us to determine the relative velocity and distance of objects in space. It also helps us to correct for any frequency shifts in communication signals, ensuring accurate and reliable data transmission.
4. How is Doppler shift used in space exploration?
Doppler shift is used in space exploration to study the motion and characteristics of objects in space, such as planets, stars, and galaxies. It is also used to track the movement of spacecraft and to communicate with them.
5. Can Doppler shift be used to determine the composition of objects in space?
Yes, Doppler shift can be used to determine the composition of objects in space by analyzing the different frequencies of light emitted or reflected by the object. This is often used in spectroscopy to identify the chemical elements present in stars and other celestial bodies.
