Double-Checking Derivative Problems: f(x)'s Explained
  • MHB
  • Thread starter MWR
  • Tags
    Derivative
In summary: If you leave out steps, even if you know what you're doing, you will miss points.In summary, the conversation revolved around double-checking the derivative of various functions, including e^(x^3 + 2), (e^-4x)/(x^3 + 7), x^3 ln x, and (^7 sqrt(x+8))/(5-6x)^8). While the correct answers were provided, it was emphasized that in order to receive full credit, it is important to clearly present all steps and explanations.
MWR
Could someone double-check my answers to these derivative problems?
-- f(x) = e^(x^3 + 2)
= 3x^2 e^(x^3 + 2)-- f(x) = (e^-4x)/(x^3 + 7)
= e^-4x [(-4x^3 - 3x^2 - 28)/(x^3 + 7)^2]-- f(x) = x^3 ln x
= 3x^2 ln(x) + x^2-- f(x) = (ln^3 sqrt(x^2))/(x^3)
= (ln)3-- f(x) = (^7 sqrt(x+8))/(5-6x)^8)
= [(x+8)/(5-6x)^8)] [(1/7) (1/x+8) + (48/5-6x)]Thanks in advance for any help. :-)
For double checking things like this, I highly suggest using Wolfram Alpha. For example, here is the output for the first derivative you listed. :)
If I were your teacher, I would mark everyone of them wrong.
You are asked to find the derivative of f and have, for example,
f(x) = e^(x^3 + 2)
= 3x^2 e^(x^3 + 2)
where, for some reason, you have said that f(x) is equal to 3x^2 e^(x^3+ 2) but have NOT said what the derivative of f is equal to!
f(x) = e^(x^3 + 2)
= 3x^2 e^(x^3 + 2)
Definitely second this. It is quite simply not enough to have the correct answer. You must present it as such; and your presentation must be logical and straight-forward.
FAQ: Double-Checking Derivative Problems: f(x)'s Explained
What is a derivative and why is it important?
A derivative is a mathematical concept that measures the rate of change of a function. It tells us how much a function is changing at a specific point. Derivatives are important because they are used to solve many real-world problems, such as calculating the velocity of an object or finding the maximum or minimum value of a function.
Why is it necessary to double-check derivative problems?
Double-checking derivative problems is important to ensure accuracy and catch any potential errors. Derivatives involve multiple steps and calculations, so it is easy to make mistakes. Double-checking allows us to verify our work and make sure we have the correct solution.
What are common mistakes people make when finding derivatives?
Common mistakes when finding derivatives include incorrect application of the rules of differentiation, forgetting to take the derivative of each term in a function, and errors in algebraic simplification. It is also important to pay attention to signs and make sure they are applied correctly.
How can I improve my understanding of derivatives?
To improve your understanding of derivatives, it is important to practice solving problems and familiarize yourself with the rules of differentiation. You can also seek out additional resources, such as textbooks or online tutorials, to further your understanding. It can also be helpful to work through problems with a tutor or study group.
What are some real-world applications of derivatives?
Derivatives have many real-world applications, including calculating the velocity and acceleration of objects, determining the slope of a curve, finding the maximum and minimum values of a function, and solving optimization problems. They are also used in fields such as physics, economics, and engineering.
