Double integral and Green's theorem
In summary, the conversation discussed the possibility of calculating a double integral by converting it to a line integral using Green's Theorem. It was also mentioned that the region of integration must meet certain criteria and that the path of integration must be taken along a positively oriented, piecewise smooth, simple closed curve in a plane.
rashida564
220
Hi everyone, I was wondering if it was possible to calculate a double integral by converting it to a line integral, using the greens theorem, and if so is it possible to get a non zero answer. if we were working on a rectangular region
You have to be sure the double integral meets the Green's Theorem criteria:
https://en.wikipedia.org/wiki/Green's_theoremLet C be a positively oriented, piecewise smooth, simple closed curve in a plane, and let D be the region bounded by C. If L and M are functions of (x, y) defined on an open region containing D and having continuous partial derivatives there, then
{\displaystyle (L\,dx+M\,dy)=\iint _{D}\left({\frac {\partial M}{\partial x}}-{\frac {\partial L}{\partial y}}\right)\,dx\,dy}
c
where the path of integration along C is anticlockwise.[2][3]
NOTE: had problem getting C under the line integral.
FAQ: Double integral and Green's theorem
What is a double integral?
A double integral is a type of mathematical operation that involves integrating a function of two variables over a region in the plane. It is represented by two nested integral signs and is used to calculate the volume under a surface in three-dimensional space.
How is a double integral related to Green's theorem?
Green's theorem is a fundamental theorem in vector calculus that relates the double integral of a two-dimensional vector field over a region in the plane to a line integral around the boundary of that region. It allows for the conversion of a difficult line integral into a simpler double integral, making it a useful tool in solving problems involving vector fields.
What is the significance of Green's theorem in physics?
Green's theorem has many applications in physics, particularly in the fields of electromagnetism and fluid mechanics. It is used to calculate the work done by a force in moving an object along a path, as well as the flow of a fluid through a closed curve.
Can Green's theorem be extended to higher dimensions?
Yes, Green's theorem can be extended to higher dimensions through the use of multivariable calculus. In three dimensions, it is known as the Divergence theorem, and in higher dimensions, it is known as Stokes' theorem. These theorems all relate the integral of a vector field over a region to an integral over the boundary of that region.
What are some real-world applications of double integrals and Green's theorem?
Double integrals and Green's theorem have many practical applications, including in engineering, physics, and economics. They are used to calculate the volume of irregularly shaped objects, the flow of fluids in pipes and channels, and the work done by forces in moving objects. They are also used in image and signal processing to analyze and manipulate data.
