Double integral: Cartesian to Polar coordinates
In summary: The curve in Cartesians was ##x^2 + y^2 = y##. Converting this to polar coordinates gives ##r^2 = r\sin\theta## from which we see that ##r = \sin \theta##. ##\theta = \pi/2## is the maximum value for ##r##, so ##r = \sin \theta## does not go any higher than 1 for ##\theta## in the range we are interested in.
IsaacStats
∫∫√(x^2+y^2)dxdy with 0<=y<=1 and -SQRT(y-y^2)<=x<=0
x=rcos(theta)
y=rsin(theta)
0.5<=r=1, we get r=0.5 from -SQRT(y-y^2)<=x by completing the square on the LHS
then, 0<=theta<=pi
But, when I calculated the original integral, I got 0.2222...
When I calculate the integral with the polar coordinates, I get 0.92
Maybe you forgot the determinant of the Jacobian?
Anyway,without taking a look at your calculations,we can't help!
Well,
∫∫(r^2)drdtheta
For clarification,
http://www.math.utsc.utoronto.ca/b41/oldexams/2004ffinal.pdf
q8c
All what is required of me is to change the limits of integration
what I got is:
0<=theta<=pi
0.5<=r<=1
U need a factor of r. da=rdrdtheta
Likes 1 person
IsaacStats said:
Well,
0<=theta<=pi
0.5<=r<=1
Did you try to plot the region of integration? How did you get those limits?
Explanation:
I started out with the graph. In the first quadrant we have a quarter of a circle x^2+y^2=1 (radius = 1. In the second quadrant we have x^2+(y-0.5)^2=0.25 (radius=0.5). Then, since the function exists both in first and second quadrant, 0<=theta<=pi. Then, by my false reasoning, I made a mistake of thinking that 0.5<=r<=1.
After revising my calculations, I got 0<=theta<=pi/2, 0<=r<=1. I derived the limits for theta in the following way
0<=rsin(theta)<=1
-SQRT(rsin(theta)-(rsin(theta))^2)<=rcos(theta)<=0
rsin(theta)-(rsin(theta))^2=(rcos(theta))^2
sin(theta)=r
Then, by substituting into the first line, we have
0<=(sin(theta))^2<=1
Then, theta1=0, theta2=pi/2
Hence, r1=0, r2=1
Those bounds describe a portion of the unit circle centered on the origin in the first quadrant.
So, to get to the right conclusion do I add the area of the half of the circle centered at (0,0.5)?
Are you sure you are considering the right half of the curve x = ±√(y-y2)? For sure, this exists in both first and second quadrants, but you are only interested in the half x = -√(y-y2). Since √(y-y2) ≥ 0, what quadrant does x=-√(y-y2) lie?
In the second quadrant = > (pi/2)<=theta<=pi
0<=r<=0.5
0<=r<=0.5
I agree on the bounds for θ, but the values for r suggest a circle of radius 1/2 centered on the origin. Consider the curve x2+y2=y. Convert this to polar coordinates and you will obtain r. This value of r will depend on θ.
Thank you for correction. If (pi/2)<=theta<=pi, does it meant that sin(pi)<=r<=sin(pi/2); 0<=r<=1.
that's weird
that's weird
These bounds say that as θ goes from π/2 to π, r goes from 0 to 1. r is measured from the origin and so r is precisely 1 at only one value of θ, namely θ = π/2. (See this from a sketch). So the bounds for r have to depend on θ, otherwise you are describing a portion of the unit circle centered at the origin.
That's great!
Does this mean that we can write the integral as a sum of two integrals (first quadrant circle and second quadrant circle)
0<=theta<=n/2, 0<=r<=1 + n/2<=theta<n, 0<=r<=sin(theta)
OR( 0<theta<n (0<=r<=1 + 0<=r<=sin(theta))
IsaacStats said:
That's great!
Why did you tag on the part '0<=theta<=n/2, 0<=r<=1'? Remember x ≤ 0 so there should be nothing that describes anything in the first quadrant.
The bounds 'n/2<=theta<n, 0<=r<=sin(theta)' describe the required region. Did you draw a sketch? Convince yourself that this is the correct range for r - try out a few values of θ and see that you get reasonable values for r (r should monotonically decrease to 0 as θ sweeps from π/2 to π)
RIGHT! Function is undefined for X>0.
Therefore, n/2<=theta<=n, and 0<=r<=sin(theta)
Yes, everything makes sense?
Out of curiosity, why does not r go between 0 and csc(theta)?
The curve in Cartesians was ##x^2 + y^2 = y##. Converting this to polar coordinates gives ##r^2 = r\sin\theta## from which we see that ##r = \sin \theta##. ##\theta = \pi/2## is the maximum value for ##r##, while ##\theta = \pi## is the minimum. In between, ##r## takes values given by the sine of the angle ##\theta##.
Likes 1 person
EXCELLENT! THANKS!
I believe my mistake was looking at 0<=rsin(theta)<=1.
Thank You for your help and may numbers be in your favor.
Related to Double integral: Cartesian to Polar coordinates
What is a double integral in Cartesian to Polar coordinates?
A double integral in Cartesian to Polar coordinates is a mathematical concept used to find the area under a surface in a two-dimensional space. It calculates the area by breaking it into smaller, rectangular pieces and adding them together. This method is useful for finding the area of shapes that cannot be easily calculated using traditional methods.
How is a double integral in Cartesian to Polar coordinates different from a single integral?
A single integral calculates the area under a curve in a one-dimensional space, while a double integral calculates the area under a surface in a two-dimensional space. In Cartesian to Polar coordinates, the double integral is calculated using two integrals, one for the radius and one for the angle.
What is the process for converting a double integral from Cartesian to Polar coordinates?
The process for converting a double integral from Cartesian to Polar coordinates involves substituting the variables in the integrand with their polar coordinate equivalents. The limits of integration also need to be adjusted accordingly. The double integral can then be solved using the polar coordinate equivalents of the integration formulas.
What are the benefits of using a double integral in Cartesian to Polar coordinates?
Using a double integral in Cartesian to Polar coordinates allows for the calculation of complex areas that cannot be easily solved using traditional methods. It also allows for the integration of functions that are easier to express in polar coordinates, such as circles and spirals.
What are some real-life applications of double integrals in Cartesian to Polar coordinates?
Double integrals in Cartesian to Polar coordinates are commonly used in physics, engineering, and other scientific fields to calculate the area and volume of complex shapes. They are also used in calculating moments of inertia and center of mass for objects with rotational symmetry.
