Double integral domain with absolute value
In summary, it appears as though you are struggling to find the domain for the function. You first attempt is to find the domain for the function using the first system of inequalities, but it appears that you graphed the second system incorrectly. You then attempt to find the domain for the function using the intersection of the two graphs, but it appears that you are not doing it correctly.
DottZakapa
239
compute the double integral
double integral
D={(x,y)∈ℝ2: 2|y|-2≤|x|≤½|y|+1}
I am struggling on finding the domain of such function
my attempt :
first system
\begin{cases}
x≥2y-2\\
-x≥2y-2\\
x≥-2y-2\\
-x≥-2y-2
\end{cases}
second system
\begin{cases}
x≤y/2+1\\
x≤-y/2+1\\
-x≤y/2+1\\
-x≤-y/2+1\\
\end{cases}
i draw the graph and get the intersection for each system, then intersect the two graphs?
first system
Second
intersection between the two
is the procedure correct or in what am i doing wrong?
Perhaps focus on getting the domain for ##y## first?
It looks to me like you have the second constraint graphed wrong. x= 2|y|- 2 consists of two straight lines, the first, for [itex]y\ge 0[/itex], x= 2y- 2, is the line through (-2, 0) and (0, 1), the second, for [itex]y\le 0[/itex], x= -2y- 2, is the line through (-2, 0) and (0, -1). That you appear to have graphed correctly.
But x= (1/2)|y|+ 1 seems to be graphed incorrectly. For [itex]y\ge 0[/itex] that is x= y/2+ 1 which is a straight line through (2, 2) and (1, 0). For [itex]y\le 0[/itex] it is x= -y/2+ 1 which is a straight line through (2, -2) and (1, 0).
The region bounded by those is an "arrow head" shaped region pointing to the left. The best way to integrate over that region is probably to divide it into [itex]y\ge 0[/itex] and [itex]y\le 0[/itex]. For [itex]y\ge 0[/itex], take y going from 0 to 2 and, for each y, x going from 2y- 2 to y/2+ 1. For [itex]y \le 0[/itex], take y going from -2 to 0 and, for each y, x going from -2y- 2 to -y/2+ 1.
the graph's that you see are depicting each inequality
i've just copied and pasted the inequalities of the systems that you see in geogebra, the first mage is of the first system, the second image is related to the second system, the third is merging the two.
Are the two systems correct? in terms of inequalities combinations
the first one is studying the left side of the inequality , the second the right side. Is this the right way to study that domain?
Okay, but you should be able to get ##|y| \le 2## to start things off.
Related to Double integral domain with absolute value
1. What is a double integral domain with absolute value?
A double integral domain with absolute value is a mathematical structure that combines the concepts of an integral domain and an absolute value. It is a set of numbers that can be added, subtracted, multiplied, and divided, and has a function that assigns a non-negative value to each element. This function satisfies properties such as the triangle inequality, the non-negativity property, and the multiplication property.
2. How does a double integral domain with absolute value differ from a regular integral domain?
A regular integral domain only has operations of addition, subtraction, and multiplication, while a double integral domain with absolute value also includes the concept of absolute value. This means that in addition to the usual properties of an integral domain, the absolute value function must also be satisfied.
3. What are some examples of double integral domains with absolute value?
The most common example of a double integral domain with absolute value is the set of real numbers with the absolute value function. Other examples include the set of complex numbers with the modulus function, and the set of rational numbers with the absolute value function.
4. What are the main applications of double integral domains with absolute value?
Double integral domains with absolute value have many applications in mathematics and physics. They are used in the study of algebraic structures, number theory, and functional analysis. They also have applications in solving differential equations and optimization problems.
5. What are some properties of double integral domains with absolute value?
Some key properties of double integral domains with absolute value include the non-negativity property, which states that the absolute value of any element must be equal to or greater than zero, and the triangle inequality, which states that the absolute value of the sum of two elements must be less than or equal to the sum of the absolute values of the individual elements. They also satisfy the multiplication property, which states that the absolute value of the product of two elements must be equal to the product of their absolute values.
