Double integral, help setting up boundaries
In summary, to find the area enclosed by the circles r=1 and r=2cos theta, we determine the bounds for θ and r and set up an integral using the formula for the area of a polar region. Evaluating the integral gives us the final answer of (2π - (3√3)/4) square units.
TheAntithesis
Find the area enclosed by the circles r = 1 and r = 2cos theta
I thought setting bounds of the inner integral as from 2cos theta to 1 and the outer from -pi/2 to pi/2, though this doesn't seem to give me the correct answer. I have used wolfram to calculate and the answer the book gives is much different. Can someone please help me to set up the bounds? Thank you in advance.
When using the bounds mentioned wolfram gives an answer of -pi/2, the answer in the book is (4pi - 3root3)/6
To find the area enclosed by the circles r=1 and r=2cos theta, we can use the formula for the area of a polar region, which is given by A = (1/2)∫(r^2) dθ.
First, we need to determine the bounds for θ. Since the circles intersect at θ=π/6 and θ=5π/6, our bounds will be from π/6 to 5π/6.
Next, we need to determine the bounds for r. The inner circle has a radius of 1, so r=1 is our lower bound. For the outer circle, we can use the equation r=2cosθ to find the upper bound. Setting r=2cosθ, we get 2cosθ=2, which gives us cosθ=1. This occurs at θ=0, so our upper bound for r is 2cosθ=2, or r=2.
Now, we can set up our integral as A = (1/2)∫(r^2) dθ, with the bounds of integration as θ=π/6 to 5π/6 and r=1 to 2cosθ.
This gives us A = (1/2)∫(1 to 4cos^2θ) dθ.
Evaluating this integral gives us A = (1/2)(4π - (3√3)/2) = (2π - (3√3)/4).
Therefore, the area enclosed by the circles r=1 and r=2cosθ is (2π - (3√3)/4) square units.
Related to Double integral, help setting up boundaries
1. What is a double integral?
A double integral is a type of mathematical integration that involves finding the volume under a surface in three-dimensional space. It is represented by the symbol ∫∫ and is used to solve problems in physics, engineering, and other scientific fields.
2. How do you set up boundaries for a double integral?
To set up boundaries for a double integral, you need to define the limits of integration for both the inner and outer integrals. This is done by identifying the curves or surfaces that form the boundaries of the region being integrated and expressing them in terms of the variables of integration.
3. What are the benefits of using a double integral?
Double integrals allow us to calculate the volume under a curved surface, which is not possible with a single integral. This makes it a powerful tool for solving problems in physics and engineering, such as finding the mass of an object with a varying density or calculating the work done by a variable force.
4. Can you use a double integral to find the average value of a function?
Yes, you can use a double integral to find the average value of a function over a given region. This is done by dividing the double integral by the area of the region, which gives the average value of the function over that region.
5. How do you evaluate a double integral?
Evaluating a double integral involves calculating the inner integral first, then substituting the limits of integration into the outer integral. This process is repeated until the entire double integral is solved, resulting in a numerical value.
