Double integral in polar coordinate
In summary, the given conversation discusses how to change the expression of a double integral by using polar coordinates in an ellipse-shaped area defined by the inequality \frac{x^2}{a^2} + \frac{y^2}{b^2} \leq 1. The conversation also includes a hint to use the substitutions x = a cos θ and y = b sin θ, as this maps out an ellipse rather than a circle. The final step involves evaluating the integral using these substitutions.
agro
46
With a > 0, b > 0, and D the area defined by
[tex]D: \frac{x^2}{a^2} + \frac{y^2}{b^2} \leq 1[/tex]
Change the integral expression below:
[tex]\iint\limits_D (x^2+y^2) dx\,dy[/tex]
by using x = a r cos θ, y = b r sin θ. After that evaluate the integral.
First of all, I can already visualize that the area is an ellipse, and because of that if we want to express the outside boundary in polar coordinates, it is
[tex]r_1(\theta) = \frac{ab}{\sqrt{(b \, cos \theta)^2+(a \, \sin \theta)^2}}[/tex]
Therefore, since x^2 + y^2 = r^2, the integral can be expressed in terms of θ and r as:
[tex]\int_0^{2\pi} \int_0^{r_1(\theta)} \! (r^2)r \, dr\,d\theta[/tex]
I've also understood how this construct comes from the Riemann sums.
However, I don't understand the substitution hinted from the problem. For every random point (r, θ), clearly x = r cos θ and not x = a r cos θ! Can someone give a geometric interpretation/explanation, and from that show how one changes the integral expression?
Thanks a lot.
x = r cos θ and y = r sin θ maps out a circle, not an ellipse.
The equation of an ellipse is:
x = a cos θ
y = b sin θ
Substitute these into your integral.
Related to Double integral in polar coordinate
What is a double integral in polar coordinate?
A double integral in polar coordinate is a mathematical concept used to find the volume under a surface on a two-dimensional polar coordinate system. It involves integrating a function over a region in this coordinate system.
How is a double integral in polar coordinate different from a regular double integral?
A double integral in polar coordinate uses polar coordinates instead of rectangular coordinates. This allows for easier integration when dealing with symmetrical or circular regions.
What is the formula for a double integral in polar coordinate?
The formula for a double integral in polar coordinate is ∬f(r,θ) r dr dθ, where f(r,θ) is the function being integrated, r is the radius, and θ is the angle.
What are some applications of a double integral in polar coordinate?
Double integrals in polar coordinate are commonly used in physics and engineering to calculate moments of inertia, centers of mass, and to solve problems involving rotational symmetry. They are also used in some areas of mathematics, such as calculating areas and volumes for polar curves.
What are some tips for solving a double integral in polar coordinate?
Some tips for solving a double integral in polar coordinate include drawing a diagram to visualize the region of integration, using the appropriate limits of integration based on the shape of the region, and converting the function into polar form if necessary. It is also important to check for symmetry, as this can simplify the integration process.
