Double Integral of e^(x^4) HELP
In summary, the conversation discusses how to integrate a double integral of e^(x^4) with given bounds and the attempts made to find a solution. It is suggested to sketch the region of integration and then adjust the limits of integration in order to integrate with respect to y first.
sarahlynnuoit
Integrate Double Integral of e^(x^4), First Bound- a = 3*(sqroot(y)) and b= 2 and 2nd Bound - C = 0 and D = 8?
We have been working on this all day and we have tried changing bounds but we cannot find an solution that can be integrated and we cannot get rid of the e^(x^4)
Please help! :)
Do you by any chance mean:
[tex]\int_{0}^{8}\int_{\sqrt[3]{y}}^{2} e^{x^{4}} \ dx\ dy[/tex]
If so, then know that the lower bound is cube root of y, not 3 square root of y. That may be why you're not getting something that you can integrate when you reorder the variables. If you integrate first with respect to y, and then x, you will get something you can integrate.
So given that same problem how do you reset the limits of integration so you can integrate with respect to y first?
Sketch the region of integration [itex]2 \leq x \leq y^{1/3}[/itex] and [itex]0 \leq y \leq 8[/itex]. Now draw an arrow through your sketched region pointed in the same direction of the y-axis. The boundary the region that your arrow intersects first will be your new lower limit. The boundary of the region that your arrow intersects second will be your new upper limit.
y goes from 0 to 2, obviously. Now, for each y what bounds does x have?
That's basically what Samuelb88 is saying.
I see thanks for the info guys.
Related to Double Integral of e^(x^4) HELP
1. What is a double integral?
A double integral is a type of integral that calculates the volume under a three-dimensional surface. It involves integrating a function over a two-dimensional region, typically represented as a rectangle.
2. How do you solve a double integral?
To solve a double integral, you can use a variety of methods including iterated integrals, change of variables, and polar coordinates. It is important to carefully identify the limits of integration and follow the proper procedure for the chosen method.
3. What is the purpose of using e^(x^4) in a double integral?
The function e^(x^4) is often used in double integrals as it is a common example of an integrand that cannot be evaluated using traditional methods. It allows for the use of more advanced integration techniques and can result in interesting and complex solutions.
4. What are some common applications of double integrals?
Double integrals have many applications in fields such as physics, engineering, economics, and statistics. They can be used to calculate volumes, surface areas, and moments of inertia, among other things.
5. How can I check my solution to a double integral?
One way to check your solution to a double integral is to use a graphing calculator or software to visualize the region and compare it to your calculated result. Another method is to use the Fundamental Theorem of Calculus to take the derivative of your solution and see if it matches the original integrand.
