Double integral over a region bounded by an ellipse
In summary, the student is trying to solve a homework equation in which the "xy" term is rotated. They are stuck on figuring out what the principal axes are and what to do with the 4xy term. They are able to find the equation for a principal axis and then take its orthogonal compliment to find the other one. The solution is quite easy once they have found the equation for a principal axis.
PinkCrayon
Evaluate. ∫∫D x2 dAxy, bounded by 5x2 + 4xy + y2 = 1
∫∫D H(x,y) dAxy = ∫∫D H(u,v)[itex]\frac{\delta(x,y)}{\delta(u,v)}[/itex]dAuv
So I understand I'm supposed to find a change of variables to transform the ellipse into a circle in the uv-plane, and then transform the circle into a square in polar coordinates, which has clearly defined boundaries.
I have no problem taking the integral or making a change of variables, but I'm not sure what to pick for my uv-plane. Clearly, I want to end up with u2 + v2 = 1, but how do I figure out what to define my uv-plane as? The part that's throwing me off is the 4xy term.
The fact that the equation of the ellipse has an "xy" term means it is rotated. There are several different ways of determining the rotation. Essentially, you will get y= ax as one of the principal axes of the ellipse and taking u= y- ax will make that line the u-axis.
What would be the best method of finding the principal axes?
Sorry, I can't seem to find an edit button. By "best" method, I mean that this is a question that would typically appear on an exam and it seems like applying the principal axis theorem, making two change of variables and then taking two integrals is at least 30 minutes of work. On an exam that is 2 and a half hours long it seems to be a bit time-inefficient and stupid way of doing this question.
The reason I raise this point is because I spent 30 minutes doing some 3-D graphing question on the midterm and ended up not having enough time to finish even though the rest of the exam was somewhat straight-foward and quite easy.
Surely there's an easy way to find an equation for a principal axis (and then I can just take its orthogonal compliment to find the other one)? I can see by observation that (-1, 2) is an integer solution, but there's nothing telling me that it lies on the u-axis.
Ain't no way I could do that on a test without the textbook, Mathematica, coffee, and an hour or so
You got:
[tex]5x^2+4xy+y^2=1[/tex]
The xy term says it's rotated so use the rotation forumulas:
[tex]x=u\cos(\alpha)-v\sin(\alpha)[/tex]
[tex]y=u\sin(\alpha)+v\cos(\alpha)[/tex]
where
[tex]\cot(2\alpha)=\frac{5-1}{4}[/tex]
so [itex]\alpha=\pi/8[/itex]
Draw both of them, it's an ellipse rotated by pi/8
make those substitutions and simplify I get:
[tex](3+2\sqrt{2})u^2+(3-2\sqrt{2})v^2=1[/tex]
so I guess if you want to make it a circle, let:
[tex]a=3-2\sqrt{2}[/tex]
[tex]b=3+2\sqrt{2}[/tex]
[tex]w=\sqrt{b/a}u[/tex]
and I get:
[tex]w^2+v^2=1/b[/tex]
Is it still time to drop and add?
Sorry to revive a somewhat dead thread, but I thought about this and we can just complete the square. I spent like half an hour typing out the itex of the full solution and to my dismay, somehow hit the back button on my browser. So I'll just post the hard part. I thought I should post my solution in case anyone else is having trouble with a similar problem.
Rewrite
[itex]5x^{2} + 4xy + y^{2} = 1[/itex]
[itex]= 5x^{2} + y^{2} + 4xy + 4x^{2} - 4x^{2}[/itex]
[itex]= x^{2} + (y-2x)^{2} = 1[/itex]
So we can take (u, v) = (x, y-2x) clearly, the jacobian is 1 and to polar coordinates it's also quite easy.
Hence we are left to integrate on the rectangle, 0 <= r <= 1, 0 <= theta <= 2pi. We have x = u = rcos(theta). Thus our integral becomes:
02pi01 r3cos(theta)2dr dtheta
Related to Double integral over a region bounded by an ellipse
1. What is a double integral over a region bounded by an ellipse?
A double integral over a region bounded by an ellipse is a mathematical concept used to calculate the volume or area under the surface of a function within a specific region that is bounded by an ellipse.
2. How is a double integral over a region bounded by an ellipse calculated?
To calculate a double integral over a region bounded by an ellipse, the region is divided into small rectangles or squares. The value of the function at different points within each rectangle is then multiplied by the area of the rectangle and added together to find the total volume or area within the region.
3. What are the applications of a double integral over a region bounded by an ellipse?
A double integral over a region bounded by an ellipse has various applications in physics, engineering, and other fields. It is used to calculate the mass, center of mass, moment of inertia, and other physical properties of objects with elliptical shapes. It is also used in calculating the work done by a force on an object moving along an elliptical path.
4. Can a double integral over a region bounded by an ellipse be evaluated using software?
Yes, a double integral over a region bounded by an ellipse can be evaluated using various mathematical software such as MATLAB, Mathematica, or Maple. These software programs use numerical methods to approximate the value of the integral.
5. Are there any special techniques for evaluating a double integral over a region bounded by an ellipse?
Yes, there are certain special techniques, such as changing the order of integration or using polar coordinates, that can make the evaluation of a double integral over a region bounded by an ellipse simpler and more efficient. It is important to choose the appropriate technique based on the given function and region to get an accurate result.
