Double integral using transformations
In summary, x=\frac{u}{1+v} and y=\frac{uv}{1+v} transform to \frac{x+y}{x^2}e^{x+y}=\frac{(1+v)^2 e^u}{u} and dxdy=J.dudv. J=\frac{v(1+v)^2 +1+uv}{(1+v)^3}. The double integral becomes: \int\int \frac{e^u[v(1+v)^2+1+uv]}{u(1+v)}.dudv which is impossible to solve without the exponential integral.
DryRun
http://s2.ipicture.ru/uploads/20120109/dT4m6rNG.jpg
The attempt at a solution
[tex]x=\frac{u}{1+v}[/tex] and [tex]y=\frac{uv}{1+v}[/tex]
Transforming the integrand: [tex]\frac{x+y}{x^2}e^{x+y}=\frac{(1+v)^2 e^u}{u}[/tex]
[tex]dxdy=J.dudv[/tex]
[tex]J=\frac{v(1+v)^2 +1+uv}{(1+v)^3}[/tex]
The double integral becomes: [tex]\int\int \frac{e^u[v(1+v)^2+1+uv]}{u(1+v)}.dudv[/tex]
This is the part where I'm having some trouble as i broke the large integrand into smaller ones:
[tex]\int\frac{e^u[v(1+v)^2+1+uv]}{u(1+v)}.du=\int\frac{e^u v (1+v)}{u}.du+\int\frac{e^u}{u(1+v)}.du+\int\frac{e^u v}{(1+v)}.du[/tex]
The integral of [itex]\frac{e^u}{u}[/itex] is what's blocking my progress through this problem. I did an online search and it appears that it can't be solved unless i use some special function that mathematicians invented called exponential integral. So, i think i might have made an error somewhere and might have inadvertently overstepped into unknown territory. I haven't started working on the limits yet, as i wouldn't be able to integrate at this point.
Check J. ehild
[tex]\frac{\partial x}{\partial u}=\frac{1}{1+v}[/tex]
[tex]\frac{\partial x}{\partial v}=\frac{-u}{(1+v)^2}[/tex]
[tex]\frac{\partial y}{\partial u}=\frac{v}{1+v}[/tex]
[tex]\frac{\partial y}{\partial v}=\frac{u}{(1+v)^2}[/tex]
I had made a mistake in [itex]\frac{\partial y}{\partial v}[/itex]
[tex]J=\frac{u+uv}{(1+v)^3}[/tex]
The u-v graph is:
http://s2.ipicture.ru/uploads/20120109/JPuR66Sn.jpg
[tex]\int^1_0\int^2_{2v} e^u .dudv=e^2-\frac{e^2}{2}+\frac{1}{2}[/tex]
The answer is incorrect. I'm supposed to get [itex]e^2-1[/itex]
Check the boundary u=2v. It is not correct.
ehild
I'm not sure what went wrong, as my conversion from the Cartesian coordinates to uv coordinates appear correct, so here is my Cartesian graph:
http://s2.ipicture.ru/uploads/20120110/rOnUC6d7.jpg
The graph i drew is just a sketch for describing the boundaries and region area, so it's not graphically very accurate.
Converting the xy coordinates to uv coordinates (i took the x and y coordinate from each set and plugged them into the original transformations from the problem):
(x,y) --> (u,v)
(0,0) --> (0,0)
(1,1)--> (2,1)
(2,0) --> (2,0)
Transform the lines instead of the points.
From the integration domain you have the relations y≤x≤2-y and 0≤y≤1.
As x, y both are non-negative, so are u and v : u≥0, v≥0.
y≤x →v≤1
x≤2-y→x+y≤2→u≤2
y≥0 is true when u≥0, v≥0
y≤1 →u≤1/v+1 as u≥0, v≥0. As v≤1, 1/v+1≥2, and this is true when u≤2.
So you have the domain for u,v u≥0, v≥0, v≤1, u≤2.
ehild
Transforming the lines:
For the line y=1, [itex]v=\frac{1}{u-1}[/itex]
For the line y=x, v=1
For the line y=2-x, [itex]v=\frac{2-u}{u-2}[/itex]
For the line y=0, v=0
I plotted the graph for these transformed lines (quite complicated):
http://s1.ipicture.ru/uploads/20120110/TUT1Skrk.png
In the graph above, i used an online graphing calculator, and i still don't understand how [itex]v=\frac{2-u}{u-2}[/itex] can give a single straight line v=-1. For example, at the point where u=2, v=0, which is not found on the line v=-1. So i tried to make u the subject of formula and i got u=2, which makes this even more confusing. So, [itex]v=\frac{2-u}{u-2}[/itex] has actually 2 lines??
Then, i deduced the points of intersection on the uv plot based on the lines which intersect on the xy plot:
http://s1.ipicture.ru/uploads/20120110/MARBBCEA.png
y=2-x is the same as x+y=2. x+y=u, so u=2.
Include also the GT LT relations.
ehild
Not sure what you mean.:confused:
I drew the graph of u-v again and included the line u=2 and all the points of intersection:
http://s1.ipicture.ru/uploads/20120110/c1y1BkLX.png
This is probably the most complex transformation I've dealt with, yet. Is there another point of intersection where the lines v=-1 and u=2 cross each other? I can't get the correct triangular shape if i simply join all the points outwards, which result in a parallelogram. However, if i ignore the part below the line v=0, then it becomes a triangle with coordinates: (1,0), (2,0), (2,1).
The limits would then be:
For v fixed, u varies from u=v+1 to u=2
v varies from v=0 to v=1
This is wrong, as after integration, i get the answer: e
OK, I'm not ready to give up, so I'm going to revise the transformations:
For the line y=2-x, [itex]v=\frac{2-u}{u-2}[/itex]⇒u = 2 and v=-1
For the line y=0, v=0 and u=0
I get a triangle with coordinates: (0,1), (2,0), (2,1)
The integration gives me: [itex]\frac{1}{2}(e^2 +1)[/itex] which is wrong again!
[STRIKE]I get a triangle with coordinates: (0,1), (2,0), (2,1)[/STRIKE]
It is not a triangle, as v=0 and u=0 corresponds to two lines.
Investigate if u and v can be negative or not when 0<y<1 and y<x<2-y.
You are right, this is a tricky transformation. But the integral is very easy after you have found the correct boundaries. Do not give up.
ehild
I am quite sure that the new point of intersection is at (0,1) but i didn't transform the line y=1 by making u the subject of formula, which would be: [itex]u=\frac{1+v}{v}[/itex]
But i suppose that the graph of [itex]v=\frac{1}{u-1}[/itex] must be the same as [itex]u=\frac{1+v}{v}[/itex]? (i plugged in a few coordinates and it appears to be equivalent).
[itex]u=\frac{1+v}{v}[/itex]and [itex]v=\frac{1}{u-1}[/itex] are the same. And you have a point of intersection at (0,1).ehild
I've encircled the relevant points of intersection in the graph below:
http://s1.ipicture.ru/uploads/20120110/ML97PRfn.png
If i join all the points of intersection, it shows a pentagon, however, since x and y are both greater or equal to zero, u and v are likewise. This means that i get a rectangular shape, with coordinates: (0,0), (0,1), (2,0), (2,1). I'm not sure though as the shape of the x-y plot is triangular and I'm supposed to always get the same basic shape after transformation, right?
That triangle is a rectangle with one side of length zero. It is the same basic shape if you can convert to the other one by stretching and compressing. ehild
For v fixed, u varies from u=0 to u=2
The integration then gives: [itex]e^2 -1[/itex] finally!
I seriously doubt that i will have enough time and insight to do this type of problem in the exams. I might require an internet-enabled device to search for assistance here, but my request will most probably be rejected by the examiners. :redface: Thank you for your help and patience, ehild.
You are welcome. I suggest to read my post #6 again.
ehild
From your post #6, here is what I've been able to understand and deduce:
Based on the given boundaries, y≤x≤2-y and 0≤y≤1, i break them down and transform each boundary to u and/or v:
Since both boundaries for x and y are ≥0 (i based this conclusion from the x-y graph), the boundaries for u and v are also ≥0.
Hence, u≥0 and v≥0.
y≤x → uv≤u → v≤1
x≤2-y → x+y≤2 → u≤2
Therefore, 0≤u≤2 and 0≤v≤1
y≥0 → u≥0 or v≥0
y≤1 → v≤1/(u-1) or u≤(1+v)/v → u≤1/v+1
Therefore, 0≤u≤1/v+1 and 0≤v≤1/(u-1)
So, now, i ended up with 4 boundaries in u-v. I don't know what's next. I should probably plot these individually or should i compare the boundaries?
For comparison of the boundaries, I'm assuming that the u's and v's all describe the same region. Is that a correct assumption?
If i compare the 2 boundaries for u, then i get:
2=1/v+1
which gives, v=1
This would mean 0≤v≤1
If i compare the 2 boundaries for v, then i get:
1=1/(u-1)
which gives, u=2
This would mean 0≤u≤2
The comparison results seem to indicate that there was no need to do any comparisons in the first place, as the results were already obtained after the conversion from x-y to u-v coordinates earlier. The boundaries are correct as the integration gives the correct answer, but I'm not sure about this method. It's too easy compared to the graphical method that I've done previously.:smile: I'll have to reproduce this simpler method on other similar problems to verify its validity.
You can apply the method together with plotting the boundaries.
This problem was quite challenging. I had to work with it quite much.
ehild
Related to Double integral using transformations
1. What is a double integral using transformations?
A double integral using transformations is a mathematical technique used to evaluate the area under a curved surface in two-dimensional space. It involves transforming the original coordinates of the surface into new coordinates, which makes it easier to calculate the integral.
2. Why do we use transformations for double integrals?
Transformations allow us to simplify the calculation of double integrals by changing the coordinates of the surface to a new system that is easier to work with. This makes it possible to solve complex integrals that would be difficult or impossible to evaluate using traditional methods.
3. What are the most common types of transformations used for double integrals?
The most commonly used transformations for double integrals are polar, cylindrical, and spherical coordinates. These transformations are particularly useful for evaluating integrals involving circular, cylindrical, or spherical regions.
4. How do you set up a double integral using transformations?
To set up a double integral using transformations, you first need to identify the region of integration and choose a suitable coordinate transformation. Then, you need to determine the limits of integration for the new coordinates and rewrite the integrand in terms of the new coordinates. Finally, you can evaluate the transformed integral using standard integration techniques.
5. What are the benefits of using transformations for double integrals?
Using transformations for double integrals can greatly simplify the calculation process, making it possible to solve integrals that would be otherwise difficult or impossible to evaluate. They also allow us to work with different coordinate systems, which can be helpful in certain applications such as physics and engineering.
