Double integral with infinite limits
In summary, the conversation discusses a conjecture about the equivalence of two double integrals, one involving a function ##f(y)## and the other involving the function ##xf(x)##. The conversation provides a counterexample to the conjecture and discusses possible conditions for the conjecture to hold, as well as proposing a proof for its validity.
NotEuler
58
I have the following problem and am almost sure of the answer but can't quite prove it:
##f(y)## is nonnegative, and I know that ##\int_0^{\infty } f(y) \, dy## is finite.
I now need to calculate (or simplify) the double integral:
$$\int_0^{\infty } \left(\int_x^{\infty } f(y) \, dy\right) \, dx$$
Now, I have a conjecture that this can be written as
$$\int_0^{\infty } x f(x) \, dx$$How could I go about proving such a thing?
Isn't ##f(x) = \dfrac 1 {x^3}## a counterexample to your conjecture?
It doesn't look like the integral ##\int_0^{\infty } f(y) \, dy## is finite with that function? So the conditions are not met.
But actually ##f(y) = \frac{1}{(y+1)^2}## does seem to be a counterexample: the inner integral converges, but the outer one does not. So I suppose the conjecture isn't true in general. Could it still be true if both integrals converge? At least numerical examples suggest so, and a similar construction using infinite sums seems to give a similar answer to my guess.
Here's an example of where my guess works:
##f(y) = \frac{1}{(y+1)^3}##
Then:
##\int_0^{\infty } \left(\int_x^{\infty } f(y) \, dy\right) \, dx = \int_0^{\infty } \ \frac{1}{2 (x+1)^2} \, dx = 1/2 ##
And also:
##\int_0^{\infty } x f(x) \, dx = 1/2##
So my guess gives the correct answer with this example (and many others).
Now I am wondering if my counterexample really is a counterexample.
##\int_0^{\infty } \left(\int_x^{\infty } f(y) \, dy\right) \, dx## and ##\int_0^{\infty } x f(x) \, dx## both diverge with ##f(y) = \frac{1}{(y+1)^2}##, so I suppose from that perspective the conjecture still holds?
Either ##\int_0^{\infty } \left(\int_x^{\infty } f(y) \, dy\right) \, dx = \int_0^{\infty } x f(x) \, dx## or both of them diverge to infinity and are still 'equal' in that sense.
I'll stop talking to myself now...
Replace ##f## by ##F'## (where ##F## is the antiderivative of ##f##) in both integrals, integrate-by-parts in the second integral, and then compare it to the first.
Ah yes, I think I see at least partly. If I write ##F(x)=-\int_x^{\infty } f(y) \, dy##, then ##\int_0^{\infty } x f(x) \, dx = \int_0^{\infty } x F'(x) \, dx = [xF(x)]_0^∞ - \int_0^{\infty } F(x) \, dx##.
##[xF(x)]_0^∞## goes to 0 at the lower limit if ##F(x)## converges, but I am not quite sure how I can justify it going to zero at the upper limit. On the other hand, the last term ##- \int_0^{\infty } F(x) \, dx = \int_0^{\infty } \left(\int_x^{\infty } f(y) \, dy\right) \, dx ##. So, apart from the upper limit of ##[xF(x)]_0^∞## I think I get this. Many thanks!I had another idea, but I am not sure what the conditions are for it to be valid. The integration limits specify a triangle to the right of the y-axis and above the liny y=x. So can I then change the order of integration as follows:
##\int_0^{\infty } \left(\int_x^{\infty } f(y) \, dy\right) \, dx = \int_0^{\infty } \left(\int_0^{y } f(y) \, dx\right) \, dy = \int_0^{\infty }\left([xf(y)]_0^y \right)\, dy = \int_0^{\infty }\left(yf(y) \right)\, dy = \int_0^{\infty }xf(x) \, dx##
The new integration limits seem to specify exactly the same area, but again I am not sure exactly how to justify this.
Let [itex]R > 0[/itex] and integrate [itex]xf(x)[/itex] by parts: [tex]
\begin{split}
\int_0^R xf(x)\,dx &= \left[ x\int_0^x f(y)\,dy\right]_0^R - \int_0^R \int_0^x f(y)\,dy\,dx \\
&= \int_0^R 1\,dx \int_0^R f(y)\,dy - \int_0^R \int_0^x f(y)\,dy\,dx \\
&= \int_0^R \left( \int_0^R f(y)\,dy - \int_0^x f(y)\,dy\right)\,dx \\
&= \int_0^R \int_x^R f(y)\,dy\,dx. \end{split}[/tex] Now take the limit [itex]R \to \infty[/itex]. (Note that not all of these steps are valid if you start with [itex]R = \infty[/itex].)
\begin{split}
Thanks pasmith, looks great. One question: Is it always valid to take the limit of the two R:s in the last integral simultaneously? What I mean is that in the integral ##\int_0^{\infty } \left(\int_x^{\infty } f(y) \, dy\right) \, dx## it seems like the two infinities are 'separate'. In your solution the two R:s go to infinity at the same time. Can there be situations where these two are different?
I think you can ignore how the two R's go to infinity at the same time because you're integrand is non-negative. You usually only have to worry about stuff like that when your infinite sum/ integral does not converge absolutely.
The idea is to change to order of the integrations. Let's rewrite the integral in the physicists' notation first, which is more clear concerning the order of integrations:
$$I=\int_0^{\infty} \mathrm{d} x \int_x^{\infty} \mathrm{d} y f(y).$$
You integrate over the "upper triangle" of the plane ##[0,\infty] \times [0,\infty]##. So changing the order of integrations you get
$$I=\int_0^{\infty} \mathrm{d} y \int_0^y \mathrm{d} x f(y)=\int_0^{\infty} \mathrm{d} y y f(y).$$
Now you can call the integration variable anything you like. So renaming the ##y## to ##x## leads to
$$I=\int_0^{\infty} \mathrm{d} x x f(x).$$
Of course, all this is valid only, if the integrals exist/converge ;-)).
In general, the switching can be justified. You can make upper limits finite and let to infinity.
FAQ: Double integral with infinite limits
What is a double integral with infinite limits?
A double integral with infinite limits refers to the integration of a function over a two-dimensional region that extends infinitely in one or more directions. This type of integral is often used in calculus to find the volume under a surface defined by a function over an unbounded region.
How do you set up a double integral with infinite limits?
To set up a double integral with infinite limits, you first identify the function to be integrated and the limits of integration. For example, if you want to integrate a function f(x, y) over the entire xy-plane, you would set up the integral as follows: ∫∫ f(x, y) dx dy, with the limits of integration extending to negative and positive infinity for both x and y.
What are common techniques for evaluating double integrals with infinite limits?
Common techniques for evaluating double integrals with infinite limits include changing the order of integration, using polar or spherical coordinates to simplify the region of integration, and applying Fubini's theorem to separate the integral into iterated integrals when applicable. Additionally, one might use convergence tests to determine if the integral converges or diverges.
What does it mean for a double integral with infinite limits to converge?
A double integral with infinite limits converges if the value of the integral approaches a finite number as the limits of integration extend to infinity. This means that the total "area" or "volume" represented by the integral is finite. If the integral does not approach a finite value, it is said to diverge.
Can you provide an example of a double integral with infinite limits?
Sure! An example of a double integral with infinite limits is the integral of the function f(x, y) = e^(-x^2 - y^2) over the entire xy-plane. The double integral is set up as follows: ∫∫ e^(-x^2 - y^2) dx dy, with both limits extending from -∞ to ∞. This integral converges to π, which represents the total "volume" under the surface defined by the function over the infinite region.
