Double Integrals using Polar Coordinates
In summary: So to set up the integral, you could write:∫∫Rarctan(y/x) dA = ∫0^∏/4 ∫1^2 r^2 \tan^{-1} \left( \frac{r \sin \theta}{r \cos \theta} \right) r dr dθIn summary, the problem involves finding the double integral of arctan(y/x) over a region R, where R is defined by the inequalities 1 ≤ x^2 + y^2 ≤ 4 and 0 ≤ y ≤ x. The region can be described in terms of polar coordinates as 0 ≤ r ≤ 2 and 0 ≤ θ ≤ π/4.
ThiagoG
∫∫Rarctan(y/x) dA, where R={(x,y) | 1[itex]\leq[/itex]x2+y2[itex]\leq[/itex]4, 0[itex]\leq[/itex]y[itex]\leq[/itex]x
x=rcos(θ)
y=rsin(θ)
x2+y2=r2
I know that the range of r is 1 to 2 but I can't figure out how to change the second part into θ. If I change y and x to rsin(θ) and rcos(θ), respectively, I'm not sure what to do after this point. How would I get the theta by iteslf?
The limits or intervals of integration are sometimes easier to see if you look directly at the geometry of the region, as opposed to its algebraic representation in terms of coordinate equations.
Can you sketch the region of points that solves the pair of inequalities represented by 0 ≤ y ≤ x ? How would you describe the region you sketched in terms of r and θ ?
Remember the intuitive descriptions of r and θ that lead to the definition of the equations you cited. θ is meant to denote the counterclockwise angle between the point's radius (or position vector) and the positive x-axis. r is just meant to be the distance between the point and the origin, or the length of the point's position vector.
In the region described by those two inequalities, what is the minimum possible value of θ ? The maximum ? Is r restricted in any way ?
Likes 1 person
x=rcos(θ)
y=rsin(θ)
x2+y2=r2
Draw a picture of the region. Think of a windshield wiper cleaning the region. What values of ##\theta## would it sweep through?
Likes 1 person
x=rcos(θ)
y=rsin(θ)
x2+y2=r2
Look at [itex]\frac yx = \tan \theta[/itex].
So would it be from 0 to ∏/4?
After I drew it, I think it's ∏/4 because y=x bisects the first quadrant which would mean it is at ∏/4. So it ranges from 0 to ∏/4
That's it exactly. :) The limits you have for r are perfect as well.
FAQ: Double Integrals using Polar Coordinates
What are polar coordinates?
Polar coordinates are a way of defining the location of a point in a two-dimensional plane using a distance (r) from a fixed point (the origin) and an angle (θ) from a fixed reference direction.
How are double integrals used in polar coordinates?
In polar coordinates, double integrals are used to calculate the volume of a three-dimensional shape that has a polar coordinate representation. They are also used to find the area of a region on a polar graph.
What is the formula for converting a double integral from Cartesian coordinates to polar coordinates?
The formula for converting a double integral from Cartesian coordinates to polar coordinates is: ∬f(x,y)dA = ∬f(r,θ)rdrdθ, where r is the distance from the origin and θ is the angle from the positive x-axis.
What are the advantages of using polar coordinates for double integrals?
One advantage of using polar coordinates for double integrals is that they can simplify the calculation process for certain shapes, such as circles and sectors. They also allow for easier visualization of the region being integrated over.
Can any shape be represented using polar coordinates?
No, not all shapes can be represented using polar coordinates. Polar coordinates are best suited for circular and symmetric shapes, but they can also be used for some non-circular shapes if they can be represented by a polar function.
