Double integration - switching limits
In summary, "Double integration - switching limits" refers to the mathematical technique used to interchange the order of integration in a double integral. This process is applicable under certain conditions, particularly when the region of integration is rectangular or can be transformed into such. The key steps involve determining the new limits of integration based on the original limits and ensuring that the integrand remains continuous over the new region. This technique simplifies the calculation and can lead to easier evaluation of double integrals.
laser
104
See description
Yes
I get that the bottom answer isn't a constant - but does this physically represent anything? When I set the two answers equal to each other, I get x = +- 1/sqrt(2) and I am wondering if this represents anything significant.
I don't think (mathematically) there is anything wrong with the bottom method - it just doesn't give the desired answer. Is this correct?
The second method is invalid. You can't take the dummy variable ##x## outside the integration by ##dx##. Instead, you must change the bounds on the integral to be valid for doing the integration by ##dx## first.
Likes FactChecker and laser
Ya I'm aware that the proper way of doing it is by changing the bounds such that you have constants on the outer integral. I guess I was looking for an explanation for why you must have constants on the outer integral. And that's because ##x## is a dummy variable like you said if I understand correctly.
Likes FactChecker and PeroK
Doesn’t it make sense that if you want a hard number in the end that each subsequent integration should be more and more restrictive?
I recommend sketching the region you’re integrating over and deciding your new bounds from there.
Switching the order of integration does not always mean you can carry the bounds with you. That only works when you are given solid numbers for bounds of x and y.
Likes WWGD
Yeah it does, I was just wondering.
That is what I usually do!
Fair enough.
Likes PhDeezNutz
Also for this specific problem, you’re going to have to break the Region into two parts to do the integration.
Likes laser
To expand the problem with the second approach a little more:
In the first approach, the inner integral is evaluated for the particular 'x' value in the lower limit, so that x value makes the outer integral make sense.
In the second approach, the inner integral is a constant and 'x' is no longer defined, so the outer integral using 'x' does not make sense. 'x' does not have a defined value for the outer integral.
Likes laser
To reinforce the point on the outer limits of integration, notice the integral spits out a number. If you instead include a formula, no such number will result. Not too deep, but arguably a good heuristic.
Likes PhDeezNutz
FAQ: Double integration - switching limits
What is double integration?
Double integration refers to the process of integrating a function of two variables over a two-dimensional area. It involves calculating the integral of a function with respect to one variable while treating the other variable as a constant, and then integrating the resulting expression with respect to the second variable.
What does it mean to switch limits in double integration?
Switching limits in double integration means changing the order of integration, which can be necessary when the region of integration is more easily described by the other variable. This involves adjusting the limits of integration to reflect the new order while ensuring that the area being integrated over remains the same.
When should I switch the limits of integration?
You should consider switching the limits of integration when the region of integration is more conveniently described in the new order, or when it simplifies the computation. This is often the case when dealing with complex boundaries or when one order of integration leads to simpler integrals than the other.
How do I determine the new limits after switching?
To determine the new limits after switching, you need to analyze the region of integration carefully. Sketching the area can help visualize the boundaries. You then express the limits of the new integral in terms of the new variable, ensuring that they accurately represent the same region of integration as the original limits.
Can switching limits affect the result of the integration?
No, switching the limits of integration does not affect the final result of the double integral, as long as the limits are correctly adjusted to represent the same region. The value of the integral remains the same, but the method of computation may become easier or more complex depending on the order chosen.
