Double-paned window heat transfer
In summary, the problem involves a double-paned window with two glass panes and an air layer in between. The temperature on one side is 0.00°C and on the other side is 20.0°C. The thermal conductivity of glass is 36 times greater than that of air. The goal is to approximate the heat transfer through the window and the temperature difference across each pane of glass. The heat transfer through the air can be calculated using the formula H = (kAdeltaT)/L, where A is the area of the air section and deltaT is the temperature difference of 20.0°C. The temperature difference across each glass pane can then be found using the approximate heat flow calculated in part (a
aoc0708
Consider a double-paned window consisting of two panes of glass, each with a thickness of 0.500 cm and an area of 0.745 m2, separated by a layer of air with a thickness of 1.95 cm. The temperature on one side of the window is 0.00°C; the temperature on the other side is 20.0°C. In addition, note that the thermal conductivity of glass is roughly 36 times greater than that of air.
(a) Approximate the heat transfer through this window by ignoring the glass. That is, calculate the heat flow per second through the 1.95 cm of air with a temperature difference of 20.0 C°. (The exact result for the complete window is 17.6 J/s.) Express your answer with three significant digits.
(b) Use the approximate heat flow found in part (a) to find an approximate temperature difference across each pane of glass. (The exact result is 0.141 C°.) Express your answer with three significant digits.
H = (kAdeltaT)/L
I've only gotten as far as A; I've tried setting up the equation like this:
30.5L = [36k(air)*2(.745)*20] + [k(air)*A(air)*20]
but there are too many variables to work with. My main goal was to find the area so I could find the heat transfer through air separately, but for some reason even when I plug in the actual values of k for glass and air it doesn't work. Assistance is welcome!
I think you can assume that the area of the air section is the same as the area of the glass panels.
By the looks of your working, it seems as if you are assuming that there is a 20 degree temperature difference across each pane of glass, as well as 20 degrees across the air. The question is saying that the outside of one of the glass panes is 0 degrees, and the outside of the OTHER glass panes is at 20 degrees. The temperature gradient across each individual pane and the air gap will be less than 20 degrees, but they will sum to a total of 20.
Related to Double-paned window heat transfer
1. How do double-paned windows reduce heat transfer?
Double-paned windows have two layers of glass with a layer of air or gas in between. This layer of air acts as an insulating barrier, reducing the amount of heat that can pass through the window. Additionally, the glass panes are coated with low-emissivity (low-e) coatings that reflect heat back into the room, further reducing heat transfer.
2. How much more effective are double-paned windows compared to single-paned windows?
Double-paned windows are significantly more effective at reducing heat transfer than single-paned windows. On average, double-paned windows can reduce heat transfer by up to 50%, compared to single-paned windows.
3. Can double-paned windows also reduce sound transfer?
Yes, double-paned windows can also reduce sound transfer. The two layers of glass, along with the insulating layer of air, can help block out external noise. This is especially beneficial for homes located in noisy areas.
4. Are there any downsides to using double-paned windows?
The main downside of double-paned windows is the cost. They are generally more expensive than single-paned windows. Additionally, if the seal between the two panes of glass is broken, it can reduce the effectiveness of the window and may need to be repaired or replaced.
5. Can double-paned windows help with energy efficiency?
Yes, double-paned windows can significantly improve the energy efficiency of a building. By reducing heat transfer, they can help keep the interior cooler in the summer and warmer in the winter, reducing the need for heating and cooling systems. This can lead to energy cost savings for homeowners and businesses.
  • Thermodynamics
