Double root of equation with Newton Raphson
  • Thread starter Raghav Gupta
  • Tags
    Newton Root
In summary: This root-counting is apparent even without plotting. For x > 0 there are no roots of p(x) (as you have pointed out) because all coefficients of orders strictly smaller than p(x) vanish in a Taylor expansion of p(x) around x = 0.
Raghav Gupta
1,011
76
Find a double root of the equation ## f(x)= x^3+15.87x+24.34 ## correct to 3 decimal places.
By Newton Raphson's Formula,
## x_{n+1}=x_n + \frac{f(x_n)}{f'(x_n)} ##
##f'(x)=3x^2+15.87 ##
Does a double root means to find two roots or a root which is repeated two times?
I checked analytically with my calculator and this equation has 1 real root and 2 complex roots.
So how to proceed?
The latter. More generally, if ##f: \mathbb{R} \to \mathbb{R}## is not a polynomial but still a smooth function, then ##x_0## is called a root of order ##n \ge 1## if all coefficients of orders strictly smaller than ##n## vanish in a Taylor expansion of ##f## around ##x_0## while the ##n##th order coefficient itself is non-zero.
So how to proceed?
I agree with you and don't see any double roots here.
Likes Raghav Gupta
But suppose we don't know analytically before and we apply this formula,
## x_{n+1}=x_n +2 \frac{f(x_n)}{f'(x_n)} ##
Since multiplicity is 2.
What we can infer from that?
Eventually it will also give a root.
How many iterations to do and what initial guess value to take?
##x_{n+1}=x_n +2 \frac{f(x_n)}{f'(x_n)}##
When you start "Newton" close to a root that is not simple, you are going to run into trouble because ##f'(x_0) = 0##. I don't understand why you would put a "2" in front of the quotient, this is not going to help. "Newton" can only be used when ##f## is regular at ##x_0##. Incidentally, you got a sign incorrect, it should be
x_{n+1}=x_n - \frac{f(x_n)}{f'(x_n)}
But in any case, for your function there are no double roots and using Newton you will only be able to find the one real root.
NO! You cannot just modify Newton-Raphson like you have done. The fact is that Newton-Raphson will fail in the case of a root of multiplicity > 1 (double root, triple root, etc). Because of roundoff errors and other finite-wordlength arithmetical errors, it will also be unreliable (or fail) if the root is not double, but if there are two separate roots "very close together". Good numerical schemes must build in safeguards against such difficulties.
Anyway, Newton-Raphson works perfectly well in this example, because there are no double roots.
So how to proceed?
I used Wolfram Alpha to graph the function.
Clearly there is only one real root. Of course this is apparent if one considers the first derivative, which is positive definite.
Changing the sign of the linear term gives ##\ x^3-15.87x+24.34 \ ##, which still has only one real root, but does have a minimum of ≈ 0.006 .
Finally, subtracting 0.006 gives the function ##\ g(x)=x^3-15.87x+24.334 \ ##. It appears that g(x) has two roots, one of which is a double root.
Maybe there are two typos in the posted problem.
Added in Edit:
(Ray makes a good point in the following post.)
This root-counting is apparent even without plotting. For x > 0 there are no roots of p(x) (as you have pointed out) because all terms are > 0. For x < 0 there is a single root (as determined, for example, by Descarte's Rule of signs, applied to q(x) = p(-x).
Likes SammyS
Related to Double root of equation with Newton Raphson
What is the concept of Double root of equation with Newton Raphson?
The concept of Double root of equation with Newton Raphson is a numerical method used to find the roots of a given equation. It is based on the Newton-Raphson iterative method, which uses an initial guess to approximate the root and then refines the guess until a desired level of accuracy is achieved.
How does Newton Raphson method work for finding double roots?
The Newton Raphson method works by using the derivative of the equation to find the slope of the curve at a given point. This slope is then used to determine the next approximation for the root. The process is repeated until the desired level of accuracy is achieved or until the root is found.
What are the advantages of using Newton Raphson method for finding double roots?
One advantage of using Newton Raphson method for finding double roots is that it is a fast and efficient method. It also has a high convergence rate, meaning it can find the root with a small number of iterations. Additionally, it can handle complex equations and multiple roots.
What are the limitations of using Newton Raphson method for finding double roots?
The Newton Raphson method may not always converge to the root or may converge to a wrong root if the initial guess is not close enough to the actual root. It also requires knowledge of the derivative of the equation, which may not always be easy to obtain. Furthermore, it may not work well for equations with multiple roots that are close together.
How is the algorithm for finding double roots using Newton Raphson implemented?
The algorithm for finding double roots using Newton Raphson involves repeatedly using the formula xn+1 = xn - f(xn)/f'(xn) until the desired level of accuracy is achieved. This process is continued until the root is found or the maximum number of iterations is reached. The initial guess and the derivative of the equation are required inputs for the algorithm.
  • General Math
  • Calculus
  • General Math
