Double Slit - any interference?
In summary, the conversation discusses the possibility of observing wave-like behavior, such as interference or diffraction, with electrons passing through a double slit with a separation of 2nm at a velocity of 20 m/s. The formula for calculating the maxima and minima of a double slit is discussed, and it is determined that if the wavelength is larger than the slit separation distance, there will be no interference fringes appearing. This is the case in the given scenario, as the wavelength is almost 20,000 times larger than the slit separation distance.
ZedCar
354
Can wave-like behaviour, eg interference or diffraction, be observed with the following?
Electrons with a velocity of 20 m/s passing through a double slit with a separation of 2nm
The solution is given in the book.
λ = 2.65 x 10^-35 m
Then it states this is too large to show interference or diffraction.
But what I'm wondering is, if the double slit separation distance and the wavelength measurement is known, can one simply know straight away that there is no interference or diffraction if the double slit separation distance is smaller than the wavelength.
As is the case here.
λ = 2.65 x 10^-35 m
That's not the correct answer. Note that 20 m/s is the velocity, not the momentum.
Then it states this is too small to show interference or diffraction.
See if you can show that λ will be too big to show double-slit interference.
Sorry. Don't know why I wrote that number.
It should be λ = 3.64 x 10^-5 m
Does that look better?
So the fact that λ is larger than the double slit separation distance, does that automatically mean there is no interference?
Yes, that look's good.
Do you know the formula for calculating the maxima or minima of a double slit?
MAX
d sin α = k λ
d ... spacing between slits
α ... angle
k ... order of the maximum (0, 1, 2, ...)
λ ... wavelength
MIN
d sin α = (k + ½) λ
α ... angle
k ... order of the minimum (0, 1, 2, ...)
λ ... wavelength
ZedCar said:
MAX
d sin α = k λ
Good. Divide both sides by d to solve for sin α. See if you can find the angle α to the first-order maximum.
For k, I made k=1
Then attempted to solve for both max and min, but got an error message.
Do the error messages indicate there is no interference?
Think about why you got an error. What is the maximum value that sin α can possibly have? (This is just a question about the properties of the sine function.) But then, if λ is greater than d, what can you say about the value of kλ/d for k = 1, 2, 3,...
Note that in this problem, λ is almost 20,000 times larger than d!
Well, sin a can equal, at most, 1.
And if λ is greater than d this would imply sin a is greater than 1, which it cannot be.
So, with sin a equalling kλ/d is greater than 1, this means there can be no interference.
Yes, if λ > d then the first-order maximum will not occur (and so neither will the second, third, or higher maxima occur). Likewise, by considering the formula for minima, you can show that if λ > 2d, then no minima will occur. In your case λ is really huge compared to d or 2d. So, there would be no interference fringes appearing.
Thanks very much TSny !
FAQ: Double Slit - any interference?
What is the double slit experiment?
The double slit experiment is a classic experiment in quantum mechanics that involves passing a beam of particles, such as photons or electrons, through two parallel slits and observing the resulting interference pattern on a screen behind the slits.
What is interference in the context of the double slit experiment?
In the double slit experiment, interference refers to the phenomenon where waves of particles, such as photons or electrons, interact with each other and produce a pattern of light and dark fringes on a screen. This pattern is a result of the overlapping of the waves from the two slits, creating constructive and destructive interference.
What is the significance of the double slit experiment?
The double slit experiment is significant because it demonstrates the wave-like behavior of particles at a macroscopic scale. It also shows the duality of particles, meaning they can behave as both waves and particles. This experiment has played a crucial role in the development of quantum mechanics and our understanding of the nature of matter.
How does changing the distance between the slits affect the interference pattern?
Changing the distance between the slits can alter the interference pattern in the double slit experiment. If the distance between the slits is increased, the interference pattern will become wider, and if the distance is decreased, the pattern will become narrower. This is because the distance between the slits affects the phase difference between the waves, resulting in a change in the interference pattern.
What happens to the interference pattern if only one slit is open?
If only one slit is open in the double slit experiment, there will be no interference pattern observed on the screen. Instead, the particles will form a single bright spot on the screen, indicating that they are behaving as particles rather than waves. This result supports the idea of wave-particle duality, where particles can exhibit both wave-like and particle-like behavior.
