Double-slit diffraction with thin film interference
In summary, the conversation discusses a case of destructive interference caused by a thin sheet of plastic covering one slit of a double-slit apparatus. The minimum thickness of the plastic needed to shift the phase of the wave by λ/2 is determined by calculating the difference in the number of waves that can fit in a layer of plastic and a layer of air with the same thickness. The index of refraction for air is also mentioned as a key factor in the calculation.
grouper
52
A very thin sheet of plastic (n=1.70) covers one slit of a double-slit apparatus illuminated by 630 nm light. The center point on the screen, instead of being a maximum, is dark. What is the (minimum) thickness of the plastic?
Constructive interference d*sinθ=m*λ where m=0,1,2,3,...
Destructive interference d*sinθ=(m+1/2)*λ where m=1,2,3,...
c=λ*f
c=c0/n
λ1*n1=λ2*n2
Obviously this is a case of destructive interference so the sheet of plastic needs to shift the phase of that wave by λ/2. I am unsure of how to determine the thickness of the plastic necessary to make that happen though.
The thickness, t, of the plastic must be such that there is an extra 1/2 a wavelength in the plastic, compared to the number of wavelengths in the same thickness of air.
Index of refraction for air is ≈ 1 .
As stated above in my attempted solutions, I understand that the wavelength needs to be shifted by λ/2 but I don't understand how to use this to find out how thick the glass needs to be to shift the wave by that amount.
If λ is the wavelength in air, then λ/n is the wavelength in the plastic, right?
How many waves of wavelength, λ/n, will fit in a layer of plastic having a thickness, t ?
How many waves of wavelength, λ, will fit in a layer of air having a thickness, t ?
The difference the the above two quantities must be 1/2.
number of waves in plastic: = t/(λ/η) = ηt/λ,
number of waves in: = ?
Ok, thanks, that helped a lot. For some reason I was blanking on how to get the number of waves in the thickness of the plastic, but I figured it out.
FAQ: Double-slit diffraction with thin film interference
1. What is double-slit diffraction with thin film interference?
Double-slit diffraction with thin film interference is a phenomenon in which light passing through two narrow slits creates a pattern of light and dark fringes on a screen due to the interference of light waves. This pattern is further modified by the presence of a thin film, resulting in a more complex interference pattern.
2. How does double-slit diffraction with thin film interference occur?
Double-slit diffraction with thin film interference occurs when light waves from a source pass through two narrow slits and overlap, creating a wave interference pattern on a screen. When a thin film is placed in front of one or both of the slits, it modifies the path lengths of the light waves, resulting in a more intricate interference pattern.
3. What is the significance of double-slit diffraction with thin film interference?
Double-slit diffraction with thin film interference is significant because it provides evidence for the wave nature of light. It also demonstrates the concept of interference, which is a fundamental principle in the study of waves and optics. This phenomenon is also used in various technologies, such as optical filters and anti-reflective coatings.
4. How does the thickness of the thin film affect the interference pattern?
The thickness of the thin film has a significant impact on the interference pattern. As the thickness increases, the path length difference between the two light waves also increases, resulting in a more complex and varied interference pattern. Additionally, the type of interference (constructive or destructive) can also change based on the thickness of the thin film.
5. What are some real-world applications of double-slit diffraction with thin film interference?
Double-slit diffraction with thin film interference has several practical applications. It is used in the production of optical filters, which are used in cameras, telescopes, and other optical devices to selectively filter certain wavelengths of light. This phenomenon is also utilized in anti-reflective coatings, which reduce glare and improve the clarity of glass surfaces, such as lenses and screens.
