forcefield
- 141
- 3
double-slit experiment and "watching the electrons"
I'm trying to build a picture of what is happening in the double-hole experiment when you are "watching the electrons" (http://feynmanlectures.caltech.edu/III_01.html#Ch1-S6). It's mostly clear to me but I do have some questions: if you use a strong light source at the holes (so that you can see every electron at the holes), can you in that case use a long wavelength for the light source so that when you see a flash of light you can't tell which hole is closer to the flash of light ? If you can, is there interference in that case ?
(My hypothesis is that you can use such a long wavelength also in the case of strong light source and then there is no interference.)
