Double slit experiment -- consciousness and information
In summary: Although not allowed sources under the PF rules (that is, you can't cite them as an authoritative source about what quantum mechanics really says - for that there is no substitute for a real textbook with the math and everything) there are two books that you may find more helpful than the random internet video:Giancarlo Ghirardi: Sneaking a look at God's cardsDavid Lindley: Where does the wierdness go?The which path information is not needed for a two bar pattern to appear.
Viopia
86
I am not a physicist but I am interested in the double slit experiment and would like a definitive answer, from a physicist, to my question as follows:. If the which path is just detected by a detector, without it flashing and bleeping at the same time, and without the detections being recorded for future reference, and without a consciousness observing these detections, will a two bar pattern still appear on the target screen?
There is zero requirement that there EVER be a conscious observer. That's a mistaken point of view that was abandoned about 100 years ago but persists in pop-sci presentations. ANY white-path detection destroys the interference.
Hi Viopia,
:welcome:
You will have to post your questions in the proper forum. This one here is only for introducing yourself. But I can tell you already that no, consciousness is not needed. You will find many threads discussing this. For instance, at the bottom of this page, you will find a list of "Similar Discussions."
Likes bhobba
OOPS. Didn't realize when I responded that this was in the intro section.
DrClaude said:
Hi Viopia,
:welcome:
Thanks for the info. This being the case why is there so much current confusion over this, as demonstrated by the following YouTube link? I believe you are right, but the researchers who actually conduct the experiments also seem to be unsure about whether the which path information has to be recorded or not. Even Jim Al-Khalili's YouTube video shows the detector "flashing and bleeping" while detecting. Why does it need to "flash and bleep" if conscious observation is not required? Please take particular notice 6 minutes from the start of the video to see the complete confusion. Do you also know the answer to the first part of my question?
As I said in my post, the "confusion" ONLY persists in the minds of pop-science demonstrators. Physicists dumped the notion a century ago. The REAL question is, why don't pop-sci folks pay attention to actual science?
Likes Viopia
Good question. It does not. A silent, black body detector would have the same effect. Polarizers in each path also affect the pattern. If they are wholely opposed there is no pattern.
Likes Viopia
Stuff like this is the reason why Physics Forums has its rules about acceptable sources. You won't find this confusion in the peer-reviewed literature where the real work is going on, and you won't find it in the first-year QM textbooks that aim to teach the real thing to people who are preparing to do real work in the field.
Likes Viopia and bhobba
Thanks. So the answer to the first part of my question is the which path detectors only have to detect without recording the information for future reference for a two bar pattern to appear.
In fact just about any substantial interaction will do the trick - it's an accident of history that we use the words "observation" and "detection" to describe these interactions.
Thanks for that. Perhaps the two Texas A&M PHd research physicists should also read these books, as well as the ex NASA physicist Tom Campbell. Also, do you think Professor Jim Al-Khalili should alter his YouTube video because the detectors do not need to flash and bleep and showing them flashing and bleeping gives people the impression that consciousness is required when it really is not.
Just one last question. (It is easier for me to ask you than spending hours plowing through a textbook). There seems to be a consensus among physicists that detection "interaction" causing probability waves to become particles is very strange, especially in the delayed choice quantum erasor experiment where the particles historic pathway is created at the same time. Does the Quantum Field Theory address these issues by ignoring wave particle duality and suggesting that there are no particles, only waves. If so, does all the weirdness now have an explanation and is QFT part of mainstream science?
Likes dlgoff and phinds
Actually wave-particle duality is an outdated concept and as such it's "ignored" by every field of physics.
It was outdated at the end of 1926 when Dirac came up with his transformation theory which generally goes under the name QM today. Here is the history:
http://www.lajpe.org/may08/09_Carlos_Madrid.pdf
The wave particle idea was just an incorrect stepping stone to Schrodinger's wave equation (he even made a mistake in its derivation I will give a link about at the end) which later morphed and was combined with Matrix Mechanics by Dirac and others. It also included other ideas around at the time such as Dirac's Q numbers that Heisenberg described as much better than his own.
Here is the paper explaining what Schrodinger did, his mistake, and the modern view:
https://arxiv.org/abs/1204.0653
But please understand its purely of historical interest.
Thanks
Bill
Likes Viopia
Post the peer reviewed literature of those people, and experts here will be only too happy to explain what's going on - its likely popularization's which, how to put it, are often way oversimplified to the point of downright lies for a lay audience.
But we can't comment until you post what they say, its source and just what concerns you.
It must also be said well respected textbooks are of course suitable references here, and some of the beginner ones of those sail close to - again how to put it - not quite kosha. But you must give the source and what worries you if we are to comment.
Thanks
Bill
Likes Viopia
Opinions on if its strange or not varies. This is hardly surprising since 'being strange' is an emotional response. You don't need QFT to explain it.
To understand the 'real' fundamental issue(s) in QM you need to consult modern textbooks on interpretations, especially those dealing with what's called decoherence. The issue is, colloquially, why we get any outcomes at all, but that's by the by. I can't explain it at the lay level. THE standard text is:
https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20
Its advanced however.
At your level I suggest the following textbook that has kindly been put out there for free. It uses math, but explains it as it goes along:
http://quantum.phys.cmu.edu/CQT/index.html
It has a whole chapter devoted to the delayed choice experiment, but you must take the time to read the entire book.
But its just a start. Once you start learning QM you never really stop.
Thanks
Bill
Likes Viopia
Viopia said:
That video is trash - discontinuity in reality - I mean - really. The possibility of collecting information - if a tree falls in forest does it make a sound if there is no one to hear it. Of course it does regardless of what people may prattle on about in an introductory philosophy class. If the detector doesn't record the information - same thing. QM is a theory about observations that occur in a common-sense classical world where observation is a very general thing.
I will not go into how consciousness entered this quantum thing - suffice to say it was due to a mistake made by the very great polymath Von-Neumann (he made a couple - but that in no way diminishes his greatness) in his classic - Mathematical Foundations Of QM. It was excusable at the time but we know more now and can easily see the mistake. Start a new thread if you want to delve into it.
Be very wary about the writings of the early pioneers such as Von-Neumann. They are of course acceptable sources, but things have moved on a lot.
To cut to the chase all the quantum eraser experiment does is show in simple cases decoherence can be undone. Its a matter of definition if decoherence so simple it can be undone is a real observation - normally its so complex it can't be undone. But as you probably have guessed I don't care about semantics - take any view you want - who cares - the answer is the same.
Thanks
Bill
Likes PeroK and Viopia
Even Eugene Wigner, who at one point was perhaps the most prominent proponent of the idea that consciousness causes collapse, eventually abandoned it after he learned of H. Deiter Zeh's pioneering 1970 paper on decoherence.
Indeed. I have zero doubt so would have Von-Neumann if he was still alive.
In relation to this these days a measurement is considered to have occurred after decoherence. Its purely quantum, nothing recorded etc etc. Even a dust particle can be decohered to have an actual position by a few stray photons from the CBMR. It can be interpreted as having position regardless of if anyone observes it, records it etc etc. We have made a lot of progress in understanding the measurement problem and why there is an objective reality out there in the common-sense everyday classical world.
Thanks
Bill
Likes Viopia
Thanks
Bill
If one shields a metal pin from the CBMR using some form of container.. what kind of particle beam source can emit enough artificial CMBR or molecular disrupter that can overwhelm the position basis in the atomic structure of the metal pin enough to cause the whole metal pin to appear and vanish, etc. as the position basis and values are altered by the beam? and if this is impossible.. what would be the reason why?
You can't overwhelm the position basis as you call it. The reason objects are decohered to the position basis has to do with the radial nature of most interactions. But the detail is highly technical.
Thanks
Bill
Thanks
Bill
Yes, this seems to tie in with what Tom Campbell said in his YouTube video entitled "Tom Campbell in Calgary: Intro to MBT (Fri) 1/1" about 27m in when he says the photons or atoms could be replaced by electric toasters if the experiment could be scaled up enough. He seems to think that this is unlikely though. I would love to see two massive slits being bombarded by electric toasters crashing through, what a spectacle this would be. I did ask the RI if this could be done with something smaller, like sand particles being blasted into two slits, and I received a reply from a non-physicist member of staff who had asked members of the RI on my behalf. The reply was The grains of sand are too large/slow for the experiment. Apparently the largest particles that have ever shown an interference pattern are molecules hundreds of atoms across. Everything has a wave/particle duality (even people!, this is called the de Broglie wavelength), but the larger the thing, the smaller that wavelength and the harder it is to see. Sand is just too big to get an interference pattern with. Randomly sandblasting the two slits would result in two randomly sized piles of sand under the slits. Even though grains of sand are tiny to us, they are still massive in the world of quantum physics therefore any characteristics they display during experimentation will all adhere to the laws of classical physics e.g. Newton's three laws of motion, and we won't observe any quantum characteristics. It is interesting to note that the consensus appears to be that "everything has a wave/particles duality (even people)". I wonder why Tom Campbell's big TOE (Theory of Everything) has not been peer reviewed, after all he was a NASA physicist.
DrClaude said:
Hi Viopia,
:welcome:
Consciousness has reared its ugly head again. I looked at a YouTube video entitled "Delayed choice eraser experiment explained" which was published in 2014. 6.34 in it said that the only difference between the two (D1 and D3) is what we, the conscious observer, know about the system. Even John Wheeler himself said "it begins to look as if we, ourselves, by a last minute decision, have influence on what a photon will do when it has already accomplished most of its doing. We have to say that we ourselves have an undeniable part in shaping what we have always called the past".
Thanks
Bill
Thanks for the links. There are some strange things though. For instance I have heard that Shrodinger's Car is neither alive or dead until the box is opened. What is this all about? It's not exactly what you would call normal "belt and bracer or bricks and mortar" type of stuff.
Viopia said:
For instance I have heard that Schrodinger's Cat is neither alive or dead
That is one of the more common pieces of misinformation you'll hear. It's not true, and you will find a number of older threads here with the correct explanation. (You've mentioned another common piece of misinformation in another post above - "wave-particle duality" isn't what you've been told it is, and if you want to understand quantum mechanics you should make a serious effort to forget that you ever heard about it).
I've already mentioned the Physics Forums rule about acceptable sources. We have this rule because so much of what is out there in YouTube videos, popular books, and internet articles is either so oversimplified as to be misleading or just plain wrong.
Likes bhobba and Viopia
Nothing has a wave particle duality - its an outdated idea - see post 15.
Everything however is quantum. How the classical world emerges is still an area of active research, although much progress has been made to the point many would say its largely solved. But some key theorems are still not yet done. You will find a discussion here:
https://www.amazon.com/dp/0691004358/?tag=pfamazon01-20
Thanks
Bill
Likes Viopia
It was proposed by Schrodinger to highlight an issue with the Copenhagen interpretation as to what point the quantum classical cut is to be made. Its now solved via our better understanding of decoherence.
There is no substitute for studying an actual textbook. I think I already mentioned the Consistent Histories one:
It will take time to study it, and your thinking cap must be on, but really its the only way.
Thanks
Bill
Wheeler's statement has nothing to do with consciousness in this case. In any delayed choice experiment, the future appears to influence the past. You can take human choice out of the equation and the results are unchanged.
Likes Viopia
Thanks for all your comments. I am grateful you have taken the time to direct me to the proper sources of information. I am surprised how much incorrect information is out there regarding this subject. I have used YouTube for many things, like for DIY tasks, music composition and computer operating tutorials etc. and I have usually found it to be an excellent source of information. I believe it when you say consciousness is not required, but for me to prove all the things you say from textbooks would be difficult, to say the least, because of my poor mathematical abilities. I am still interested in physics however, and may ask you to verify some things from time to time to make sure I understand these things correctly.
  • #31
Has this now been proved, that the future influences the past? If there were no particles, only waves of energy, could the energy transfers between EM waves and standing waves imitate particles at their points of interaction making the influence of the past unecessary?
  • #32
At first glance, it is pretty compelling. But the answer is NO, it is actually interpretation dependent.
Likes bhobba
  • #33
Is there an alternative interpretation?
  • #35
DrChinese said:
Thanks for the link. I particularly like the "Many Worlds" (parallel universe level 3) interpretation which seems to suggest the universe could keep splitting trillions of times per second. Really! Don't you think it is more likely that there are no particles, only waves of energy, and the transfers of energy between EM waves and standing waves imitate particles at their points of interaction making the influence of the past unecessary?
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
