Does the Double Slit Experiment Change When We Observe Particle Paths?
In summary, the conversation discusses the possibility of detecting both interference and which-way information in a double-slit experiment. The speaker suggests using a detector Dc before the slits to confirm coincidences with detections on D0, D1, D2, or D3. The "Delayed-choice quantum eraser" experiment is mentioned as a relevant and informative study on the topic.
calinvass
159
I would like to show you my own opinion about DSE. I might be silly but I suspect data filtering issue.
Let's suppose we have a detector DA for slit A, DB for slit B and a interference detector D0.
If we consider the photon a wave pulse it means it will go either through a slit or through both. If we don't watch detector A and B we will plot all D0 photons (pulses) and some of them will interfere and create the interference pattern. When we open our "eyes" and watch detectors we correlate DA and DB with photons on D0. If we filter pulses on D0 that are not correlated we obviously won't get a diffraction pattern. DA and DB I believe , can't detect a pulse if it is not full energy. On the other hand D0 will almost always detect the recombining wave.
Waves don't interfere when we don't have the knowledge which slit they went trough. They interfere when they pass through both slits
That's all
It doesn't make sense as long as you don't explain how you want to build such detectors concretely. Note that it is not so simple to have an experiment, where you have both interference and which-way information at the same time. You never can have interference for the same ensemble of photons that has which-way information and vice versa. A very illuminating experiment is the famous "Delayed-Choice Quantum Eraser Experiment" by Kim et al:
Yoon-Ho Kim, R. Yu, S.P. Kulik, Y.H. Shih, Marlan O. Scully, PRL 84, 1 (2000)
https://arxiv.org/ct?url=http://dx.doi.org/10%2E1103/PhysRevLett%2E84%2E1&v=d0a2ac7d
https://arxiv.org/abs/quant-ph/9903047
A real experiment (including a very understandable treatment of the underlying theory) can be found at
S. P. Walborn, M. O. Terra Cunha, S. Padua, C. H. Monken, PRA 65, 033818 (2002)
http://dx.doi.org/10.1103/PhysRevA.65.033818
http://arxiv.org/abs/quant-ph/0106078
That's all
:welcome:
calinvass, you are new so you are likely not aware of forum rules. Placing forth your own personal speculation is not appropriate here. However, because questions about double slits are so common, I will address it anyway.
1. Your speculation varies from the standard quantum theoretical explanation. Individual quantum particles - which display double slit interference behavior - do not possesses a property called "full" energy. Either a particle is detected, or it is not. The only thing that is "partial" are the odds it will be detected at a particular spot when observed. That chance varies from 0 to 100%. Please note that this is true of individual particles of light (photons), electrons, ions, and even entire molecules. (There is no such thing as a "weak" individual molecule any more than there is a "weak" photon.)
2. Your idea is falsified in experiments with light. You can attach polarizers near each of the slits. When the polarizers are aligned parallel, the pattern shows interference. When the polarizers are perpendicular, there is no interference pattern. This is explained because it is possible to use polarization information to determine which slit the light passes through ONLY when the polarizers are perpendicular.
I would encourage you to read more about the basics of light and quantum physics before attempting to fashion your own counter hypotheses. The field is rich with detail, and there are many existing experiments to learn about. I am sure you will find them fascinating.
Likes vanhees71
Alright, thank you and sorry for this post
Glad you have come here. I might suggest that you read up a little more on the subject. Then return and ask a question. I think you will find that leads to very fruitful discussion of quantum behavior, and you will gain a lot from the process.
Thank for the links. There are very useful articles.
If we consider the "Delayed-choice quantum eraser", to confirm the coincidences a second BBO before the slits could be placed and an additional detector Dc. This way any photon landing on any of the D0,D1,D2,D3 or/and D4 should be correlated with a detection on Dc. For example a detection on Dc and D0, with no detection D3 and D4 would mean a pulse passing through both slits and would result in diffraction pattern.
Related to Does the Double Slit Experiment Change When We Observe Particle Paths?
1. What is the double slit experiment?
The double slit experiment is a classic experiment in physics that involves shining a beam of particles, such as electrons or photons, through two parallel slits and observing the resulting pattern on a screen. It is used to demonstrate the wave-like behavior of particles and the concept of superposition.
2. What is the significance of the double slit experiment?
The double slit experiment is significant because it challenges our understanding of the nature of particles. It shows that particles can exhibit both wave-like and particle-like behavior, and that our observations can affect the behavior of particles. This has implications for our understanding of quantum mechanics and the fundamental nature of reality.
3. What is the issue with the double slit experiment?
The issue with the double slit experiment is the interpretation of the results. The experiment has been replicated numerous times and consistently shows a wave-like interference pattern, even when only one particle is fired at a time. This has led to debates and theories about the true nature of particles and whether they are truly waves or particles.
4. How has the double slit experiment been used in other fields?
The double slit experiment has been applied in various fields, including optics, acoustics, and even psychology. In optics, it has been used to study diffraction and interference patterns in light. In acoustics, it has been used to study sound waves. In psychology, it has been used to study the effects of observation and perception on behavior.
5. What are some proposed explanations for the results of the double slit experiment?
There are several proposed explanations for the results of the double slit experiment, including the Copenhagen interpretation, which states that particles exist in a state of superposition until they are observed, and the many-worlds interpretation, which suggests that the observer and the observed particle exist in parallel universes. Other theories propose that particles have a wave-particle duality, or that the experiment is affected by hidden variables that we cannot observe.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
