A Double-Slit Experiment: Momentum & Position
Ad VanderVen
TL;DR Summary
In the double-slit experiment with two open slits, is there a fixed relationship between the momentum (p) of the particle immediately after passing through the slit and the position (q) of the impact on the screen?
Yes. The relationship is called Schrodinger's Equation for a non-relativistc massive particle.
If you wish a more specific answer you will need to formulate a more specific question.
My specific question is, that I have a formula for the probability density function of the momentum (p) of the particle immediately after it passes through the slit in the double-slit experiment with two open slits and I want to derive from that formula a formula for the probability density function of the position (q) of the impact on the screen?
Then you need to solve Schrodinger to match your specific boundary conditions in time and space. This will likely be very difficult.
There are many approximation techniques that are useful for particular situations. What does your formula look like?
It is formula (11) from Uffink and Hilgevoord. (1985):
$$\begin{align}
\phi \left(p \right) \, = \, \frac{\sqrt{2}~\sqrt{\frac{a }{\pi }}~\cos \left(A ~p \right)~\sin \left(a ~p \right)}{a ~p }
\end{align}$$
Reference
Uffink, J.B.M. and Hilgevoord, J. (1985). Uncertainty Principle and Uncertainty Relations. Foundations of Physics, Vol. 15, No. 9,
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
