Double Slit Experiment question
In summary: So we're back to the question of where the experiment was published and what exactly was measured.In summary, the assertion made in the book "Biocentrism" by Robert Lanza is that in a double slit experiment, if quarter wave plates are used to alter the polarization of photons passing through each slit, and a polarizing detecting barrier is placed at the end plate, there will be no interference pattern at the end plate. However, if either the quarter wave plates or the polarizing detecting barrier are removed, the interference pattern will reappear. The book claims that this proves the collapse of wave functions. However, it is unclear if this assertion has been tested experimentally and published in a peer-reviewed paper.
michael29
TL;DR Summary
double slit experiment with quarter wave plates and polarization detector
I read in a book the following assertion.
In a double slit experiment photons are passed through the slits and detected at the end plate.
Each of the two slits has a quarter wave plate which alters the polarization of the photons that pass through it in a way different than the other QWP.
Thus a polarizing detecting barrier at the end plate can determine which slit the photon went through.
In such an experiment, there will be no interference pattern at the end plate. i.e. the wave functions collapse.
But if one does either of two things, the interference pattern shows up. Thus if either:
  1. the quarter wave plates are removed but the polarizing detecting barrier is kept.
OR
  1. the polarizing detecting barrier is removed but the quarter wave plates are kept.
Then the interference pattern is back.
A. Is this assertion correct?
B. If yes, then where does the wave function collapse when both are in place? At the plates or the end detector?
Likes AltenatepointwaveApw
Presumably this has been tested experimentally. Does the book give a reference to the published results of such an experiment?
I wonder how the polarization detector works. Something pretty sensitive would be needed to detect the polarization of a single photon. See this paper: Single photon detector with high polarization sensitivity, for example. The problem is that (in the ideal) it would detect photons of one polarization but not photons of the orthogonal polarization. It seems to me that would certainly collapse the waveform since the only photons passing through one of the slits would be detected. The real detector described in the paper linked above only has a bias toward detecting photons of one polarization over the other, so perhaps it would only partially collapse the waveform. Over a number of trials, that might look like one bright point (collapsed waveform) superimposed over an interference pattern of reduced intensity (uncollapsed waveform).
the book is biocentrism by robert lanza (ch.8). here's a quote from there:
"If you fully learn about one, you will know nothing about the other. And just in case you’re suspicious of the quarter wave plates, let it be said when used in all other contexts, including double slit experiments but without information-providing polarization-detecting barriers at the end, the mere act of changing a photon’s polarization never has the slightest effect on the creation of an interference pattern."
can read more here (scroll down to "The Most Amazing Experiment ")
see my last post
The interference pattern does not return if the detecting barrier is removed. But we can filter out a subset of photons that will exhibit interference terms.
Let ##|A\rangle## and ##|B\rangle## be the respective states of a photon traveling through slit ##A## and ##B##. If the photons are polarised such that ##\langle A|\mathbf{r}\rangle\langle\mathbf{r}|B\rangle = 0## then we can talk about a photon traveling through a slit and landing on a screen at ##\mathbf{r}## with probabilities
$$p(A,\mathbf{r}) = \mathbf{Tr}[|\mathbf{r}\rangle\langle\mathbf{r}|A\rangle\langle A|\Psi\rangle\langle\Psi|A\rangle\langle A|\mathbf{r}\rangle\langle\mathbf{r}|]]$$
$$p(B,\mathbf{r}) = \mathbf{Tr}[|\mathbf{r}\rangle\langle\mathbf{r}|B\rangle\langle B|\Psi\rangle\langle\Psi|B\rangle\langle B|\mathbf{r}\rangle\langle\mathbf{r}|]]$$
where ##|\Psi\rangle## is the prepared state of the incident beam. Neither distribution will exhibit interference terms, and and neither will ##p(A\lor B,\mathbf{r})##.
However, we can also talk about the photons passing through the slits in terms of the states ##\{|+\rangle,|-\rangle\}##, which are symmetric and anti-symmetric states expressed as superpositions of the two slits. These terms don't carry information about which slit the photon traveled through. The corresponding probabilities are
$$p(+,\mathbf{r}) = \mathbf{Tr}[|\mathbf{r}\rangle\langle\mathbf{r}|+\rangle\langle +|\Psi\rangle\langle\Psi|+\rangle\langle +|\mathbf{r}\rangle\langle\mathbf{r}|]]$$
$$p(-,\mathbf{r}) = \mathbf{Tr}[|\mathbf{r}\rangle\langle\mathbf{r}|-\rangle\langle-|\Psi\rangle\langle\Psi|-\rangle\langle -|\mathbf{r}\rangle\langle\mathbf{r}|]]$$
These two distributions will exhibit interference fringes, though ##p(+\lor -,\mathbf{r})## won't. So if we select either distribution by filtering out the other (e.g. with a procedure similar to the one outlined here https://arxiv.org/pdf/quant-ph/0106078.pdf ) we can observe interference terms.
Which is a popular book, not a textbook, and is not a valid reference for PF discussion.
michael29 said:
see my last post
Your link is to a post on a blog, not a textbook or peer-reviewed paper. Given some of the other content on the blog, I'm not inclined to take for granted that its explanation of the experiment in question is reliable.
Since no valid references have been provided, this thread will remain closed.
FAQ: Double Slit Experiment question
What is the Double Slit Experiment?
The Double Slit Experiment is a classic experiment in physics that demonstrates the wave-particle duality of light and matter. It involves shining a beam of particles, such as photons or electrons, through two parallel slits and observing the resulting pattern on a screen behind the slits.
What is the significance of the Double Slit Experiment?
The Double Slit Experiment is significant because it challenges our understanding of the nature of light and matter. It shows that particles can exhibit wave-like behavior and that the act of observation can affect the behavior of particles. This has implications for our understanding of quantum mechanics and the fundamental laws of the universe.
Who first conducted the Double Slit Experiment?
The Double Slit Experiment was first conducted by English physicist Thomas Young in the early 1800s. However, it was later refined and popularized by physicist Richard Feynman in the 20th century.
How does the Double Slit Experiment work?
In the Double Slit Experiment, a beam of particles is directed towards two parallel slits. These particles pass through the slits and create an interference pattern on a screen behind the slits. This pattern is created because the particles behave like waves and interfere with each other, creating areas of constructive and destructive interference.
What are the implications of the Double Slit Experiment?
The Double Slit Experiment has significant implications for our understanding of the fundamental laws of the universe. It challenges our traditional understanding of particles and suggests that they can behave like waves. It also raises questions about the role of observation and measurement in shaping the behavior of particles. This experiment continues to be studied and has led to many groundbreaking discoveries in the field of quantum mechanics.
