DOUBLE slit interference experiment
In summary, the conversation discusses a past question about a double slit interference experiment and how the fringe pattern changes when the apparatus is immersed in water. The conversation also mentions a website that provides summaries of introductory physics topics. The question is clarified to be about the change in fringe separation when the experiment is conducted in water instead of air, and the formula for fringe separation is mentioned.
ah lai
the double slit interference experiment is set up and the fringes are displayed on screen. Then the whole apparatus is immersed in the nearest swimming pool. How does the fringe pattern change?? Which website I can get information?? Thanks.
This is a homework problem correct? (I believe I have seen it on mastering physics.)
First, if you post your thoughts on the problem to show you have made some effort you can get help in the homework help forms here. Also, if you want a good website for summaries of intro physics topics you can try:
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
No, it's past yr question. I dun understand wat question is ? no idea.. I oledi tried to search information on internet.. still can't get it...
when the whole apparatus place on the table, dark & light pattern display on the screen if using light source.
do u think the whole apparatus including light source is immersed in the water? or using other source?
picture it this way, instead of doing the experiment in air, you are doing it in water.
what is the formula concerning the fringe separation? which of the parameters in it changes when the wave is traveling in water and not in air?
Related to DOUBLE slit interference experiment
1. What is a double slit interference experiment?
A double slit interference experiment is a classic experiment in physics that demonstrates the wave-like nature of light. It involves shining a beam of light through two parallel slits, causing the light waves to interfere with each other and create a pattern of light and dark fringes on a screen placed behind the slits.
2. What is the purpose of a double slit interference experiment?
The purpose of a double slit interference experiment is to demonstrate the wave-like behavior of light and the phenomenon of interference. This experiment has also been used to demonstrate the wave-particle duality of light, as it can produce both interference patterns and particle-like behavior.
3. How does the distance between the slits affect the interference pattern?
The distance between the slits plays a crucial role in determining the interference pattern. If the distance between the slits is smaller than the wavelength of the light being used, the interference pattern will be wider, with more fringes. If the distance between the slits is larger than the wavelength, the interference pattern will be narrower, with fewer fringes.
4. What happens to the interference pattern when a single slit is used instead of two?
When a single slit is used instead of two, the interference pattern disappears and is replaced by a diffraction pattern. This is because a single slit only allows light to pass through in one direction, while two slits allow light to pass through in multiple directions, causing interference.
5. How does the color of light affect the interference pattern?
The color of light does not have a significant effect on the interference pattern. The interference pattern is mainly determined by the wavelength of the light being used, rather than its color. However, different colors of light may produce slightly different patterns due to their different wavelengths.
