bahamagreen
- 1,014
- 52
Instead of using a single source and two slits, imagine just using two sources the same distance apart as were the slits...
The two sources are controlled by a device that has two modes of operation, selected by a two position switch labeled D and R:
D is "determined" - the emission from the left and right sources is determined respectively by a file of 0s and 1s (half of each) and an experimental run is comprised of n periods of t of only single emissions. The "which path" knowledge is known before, during, and after the experimental run.
R is "random" - the emission from the left and right sources depends on a radioactive substance that has a p=.5 decay during the same period as t above, run for the same n periods, wherein a decay causes an emission from the left source and no decay an emission from the right source. The "which path" knowledge is unknown before, during, and after the experimental run.
No interference pattern with the switch set to D? Interference pattern when set to R?
