Double-slit with half-transparent mirror
In summary: So the overall intensity will be lower than if all the photons went through both slits. In summary, when one of the slits is equipped with a half-transparent mirror, the interference pattern will be reduced by half and there will also be a blurred out pattern with no interference. This results in a combined pattern that still has a maximum at the middle point, but with reduced differences in intensity between regions with constructive vs. destructive interference. The which path information is not perfect as the intensity of each photon would still be the same, but the overall intensity and flux of photons will be smaller compared to when all photons pass through both slits.
jk22
729
24
Mentor's note: This thread has been split from https://www.physicsforums.com/threads/double-slit-with-semi-transparence.845980
What about if the wall were not transparent but one of the slits equiped with a half transparent mirror ?
Then we would half-know which path was taken hence we should only obtain a half interference but it would not be completely destroyed ?
That's correct, you can have 100% interference effects, 0% (none), or any value in-between if set up accordingly.
I will try to do the calculation, but from the onset I cannot tell if the maximum will be no more at the middle point between the slits, or if it will only diminish the interference.
The maximum will still be at the middle point. What you will see is a pattern where half of the intensity is from an interference pattern, and half from a blurred out pattern with no interference. In other words, it will look like the two are overlayed. So you basically end up with the same interference pattern, but with reduced differences in intensity between regions with constructive vs. destructive interference.
Ok. But there still is an interference and on the other hand we know which path the single photon takes since points with half intensity have gone through the half mirror?
Yes, half of the photons will create the usual interference pattern, and the other half will not.
But in some sense we get an interference pattern with the which path information ?
Yes, because the which path information is not perfect.
If we could measure the intensity of each photon then we could say which slit it passed through. I don't know what is meant by perfect.
No, the intensity of each photon would be the same. A photon with frequency [itex] f [/itex] can only have energy [itex] E = hf [/itex], where [itex]h[/itex] is Planck's constant.
But we agree that the beam passing through the half mirror will have less intensity ? Can we say the flux of photons is smaller ?
In a sense, yes. Half of the photons will pass through both slits and will generate an interference pattern, the other half pass through one slit only and do not contribute to the pattern.
FAQ: Double-slit with half-transparent mirror
1. What is a double-slit with half-transparent mirror?
A double-slit with half-transparent mirror is an optical setup that combines the principles of both the double-slit experiment and the half-silvered mirror experiment. It consists of a light source, a double-slit, and a half-silvered mirror placed between the slits and the screen. The mirror reflects half of the light and transmits the other half, creating an interference pattern on the screen.
2. How does a double-slit with half-transparent mirror work?
The double-slit with half-transparent mirror works by splitting a beam of light into two coherent beams, one passing through the slits and the other reflected by the mirror. These two beams interfere with each other, creating an interference pattern on the screen. The pattern is a result of the superposition of the two waves, where constructive and destructive interference occurs based on the path difference between the two beams.
3. What is the purpose of using a half-transparent mirror in the setup?
The half-transparent mirror serves as a way to split the light beam and create two coherent beams. It also allows for control over the intensity of the beams, as the amount of light transmitted can be adjusted by changing the angle of the mirror. This setup also allows for the visualization of both the interference pattern and the individual beams, providing a better understanding of the wave nature of light.
4. What can we learn from the double-slit with half-transparent mirror experiment?
The double-slit with half-transparent mirror experiment demonstrates the wave-particle duality of light, where light can behave as both a wave and a particle. It also illustrates the principles of interference and superposition, showing how the behavior of light can be explained by the wave theory of light. This experiment has also been used to study the properties of other types of waves, such as sound waves and electron waves.
5. What are the real-world applications of the double-slit with half-transparent mirror experiment?
The double-slit with half-transparent mirror experiment has been used in various fields, such as optics, quantum mechanics, and wave theory. It has also been used to study the properties of light and other types of waves, leading to advancements in technologies such as holography and diffraction gratings. This experiment has also been applied in the development of new technologies, such as quantum computers and advanced imaging techniques.
