ejhong
- 2
Looking for some pointers on how to approach this problem:
I'm considering a system like the following - two springs and two masses connected in sequence:
http://www.myphysicslab.com/dbl_spring1.html
I would like to find the following:
Given m1, m2, k1, k2. The springs are compressed each by a certain amount (x1start and x2start) and the velocities are set to 0. The springs can be released at any point in time. Once a spring is released and it stretches so that its stretch reaches a peak, it is clamped at that position. Once both springs reach their peak stretch the simulation is ended. Here is what I'm trying to find:
Assuming the left spring is released at t=0. At what time should the right spring be released to maximize the peak velocity of the right block.
I could iterate numerically using Runge-Kutta and try stepping up the release time of the right spring and record peak velocity of the right block but that seems very brute forced. I would like to find a better solution for this if possible.
As a side question, I was wondering if there was an analytical solution to this system?
Thanks for any pointers.
