I Doubling Ionization of Tungsten: Effects on Energy?
Doubling the ionization of tungsten atoms results in twice the energy gain when accelerated through the same electric potential. While the initial question about a mole of tungsten is valid, it is more accurate to consider a single atom due to the effects of mutual repulsion among charged particles. This repulsion can diminish the practical impact of the electric potential at larger scales. Nonetheless, the principle remains that a doubly ionized atom will acquire double the kinetic energy compared to a singly ionized atom under identical conditions. Thus, the concept holds true despite the complexities introduced by larger quantities of ions.
illisil
TL;DR Summary
Ionization and the relationship to kinetic energy
Lets say that i have i mole of tungsten atoms. They are all ionized, only one electron is removed from each atom. If i accelerate this mole of tungsten atoms through one electron volt, i would get 96.48 kj. If the mole of tungsten was doubly ionized, two electrons removed from each atom, and accelerated through one ev, would i get twice the kilojoules?
The short answer is yes.
One persnickety comment: electron volts is a unit of energy. I think you meant one volt of electric potential.
One caveat: it would be cleaner to ask the question about a single atom rather than a mole of atoms. With many charged particles you will have to think about their mutual repulsion, and then the potential would depend on their density. The problem is that at any practical lab scale density of a whole mole of ionized atoms would have mutual repulsion so strong your one volt potential would be completely negligible in comparison. However, I get what you meant.
Even if the potential is dominated by their mutual repulsion, the idea that, given the same initial configuration, twice the charge gives twice the energy is still true. So your idea is still correct. Just, in that case, the 1 volt becomes unimportant.
Anyhow, rephrasing it, a doubly ionized atom falling through one volt of electric potential will gain twice as much kinetic energy as a singly ionized atom falling through the same potential.
Likes nasu and Dale
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
