Is the Universe's Expansion Actually Slowing Down?
In summary: Now let's say that the universe is expanding at a rate of 10 km/sec/light-year. In our imaginary universe, two stars 1 light year apart would be moving apart at 10 km/sec. If we had three stars, spaced 1 light year apart in a line, star 2 would be moving at 10 km/sec with respect to star 1, star 3 would be moving and 10 km/sec with respect to star 2 and thus star 3 is moving at 30 km/sec with respect to star 1. Every light-year between stars adds another 10 km/sec to the recession
jssamp
31
I can't be the only person to ever have this thought so I am hoping one of you star gazers can tell me what I am missing. I understand Hubble's theory and the idea of space itself expanding. My question is this. If we know the universe is expanding because of the redshift and the farther away we look, the more red the spectra are shifted, doesn't that mean in the past, expansion was greater. Since the more distant light sources are older? Where do we conclude that expansion is accelerating because more distant galaxies were moving away faster when their light started towards us. Is it just the accepted conjecture or did I miss something. Seems to me the universe was expanding faster then and is slowing now. TBH I really can't base any conclusion about current expansion based on observations of what happened 10 billion years ago.
Astronomy news on Phys.org
Think of light waves moving through space. As space expands the light wave is stretched. That means the wavelength is longer, ie. redder. So there is redshift independent of the motion of that galaxy way back when.
Likes Nemika
We observe the chemical composition of the source at the time of emission through spectroscopic measurements. We then match the pattern of emission and absorption lines to known elements, then measure the displacement of these lines relative to their rest position to derive their redshift. The spectral displacement obviously occurs after the emission lines were emitted [save for doppler shift due to proper motion], therefor happenend along the way to shift the lines further into the red. That something is called expansion of the universe. Any spectral shift due to proper motion is vanishingly tiny at cosmological distances.
The fact that red-shift increases with distance, in of itself, just tells us that the universe is expanding and gives us no clue as to whether that expansion rate has increased or decreased over time.
Let's first look at what we would see in an universe that expands at a constant rate. We'll use an imaginary universe where the expansion constant is 100 km/sec per
light-year. Two stars 1 light year apart will being moving apart at 100 km/sec. If we had three stars, spaced 1 light year apart in a line, star 2 would be moving at 100 km/sec with respect to star 1, star 3 would be moving and 100 km/sec with respect to star 2 and thus star 3 is moving at 200 km/sec with respect to star 1. Every light-year between stars adds another 100 km/sec to the recession speed.
So let's say that we measure a star to be 10 light-years away. we would measure its red-shift to give a velocity of 1000 km/sec. Off course we realize that this info is 10 years out of date. So that means that by at the time we make the measurement, that star is actually further than 10 light-years away. So what it tells us is that when that star was 10 light-years away, it was moving away at 1000 km/sec. In turn, if we see a star 30 light years away and measure its red-shift, and get a recession speed of 3000 km/sec, we know that 30 years ago, that star was 30 light years away and receding at 3000 km/sec. That matches the constant we gave above of 100 km/sec per light year and means that this universe was expanding at the same rate 30 years ago as it was 10 years ago, (or now).
To determine that the expansion rate has changed over time, we need to see a difference in the speed to distance constant as we look at further stars. For example, if we were to measure a 1000 km/sec recession in that 10 light-year star and a 3010km/sec recession in the 30 light-year star, That means that 10 years ago the expansion rate was 100 km/sec per light year, but 30 years ago it was ~100.33 km/sec per light year, and the expansion rate of our universe had slowed during the intervening 20 yrs.
Conversely, if that we measured a 2990 km/sec speed for that 30 light-year star, then we have to conclude that the expansion rate had increased over the 20 yrs.
So basically, if you plot red-shift/recession speed vs distance:
With a constant rate expansion, you get a straight line with red-shift increasing with distance.
With a decreasing expansion rate you get a curve that deviates from that straight line in one direction.
With an increasing expansion rate you get a curve that deviates in the other direction.
In all of these cases, you see an increasing red-shift with increasing distance with an expanding universe, it is how red-shift changes with distance that distinguishes between the three cases. The fact that the universe was expanding was noted in 1929, but it wasn't until 1998 that the measurements that indicated that accelerating nature of this expansion were made.
Likes jssamp, zdroide and Bandersnatch
Thank you, it finally makes sense. Now if I could just figure out the D field and polarization density.
The inflation theory is popular and to some extent believable (to me), though I'm not sure if there is evidence as such.
It suggests that early universe expansion rate was unimaginably fast, but lasted only for a very short amount of time.
Things then settled down a bit ( a phase change), 'matter' as far as we know it came into existence,.
Things still are are expanding now according this, but it's a bit more relaxed.
That, and the other scenarios, are line-of-sight, which is appropriate for sighting light for red shift.
What about the lateral dimensions, geometrically? That is, with expansion, pairs of past light sources (large galactic clusters) would have been "closer together" geometrically, yet we are observing their subtended arc on the sky in present time, so their "lines of sight" are bent closer at our receiving end and the sourcing ends have spread apart with expansion since emission... in expansion, distant emission sources will have been closer together than when they are subsequently viewed much later, so the lines of sight must have bent.
With varying rates of expansion, I'm thinking that maybe this geometric bending of the lines of sight might not be but partially corrected.
Related to Is the Universe's Expansion Actually Slowing Down?
1. What evidence supports the theory of an expanding universe?
The most significant evidence for an expanding universe comes from the observation of redshift in distant galaxies. This means that the light from these galaxies is shifted towards the red end of the spectrum, indicating that they are moving away from us. Additionally, the cosmic microwave background radiation, leftover from the Big Bang, also supports the theory of an expanding universe.
2. How does the expansion of the universe work?
The expansion of the universe is driven by the force of dark energy, a mysterious energy that makes up about 70% of the total energy in the universe. As the universe expands, the distance between galaxies also increases, causing them to move further and further apart. This expansion is not happening within space, but rather the space itself is expanding.
3. What is the role of gravity in the expansion of the universe?
Gravity plays a counterbalancing role in the expansion of the universe. While dark energy is pushing galaxies apart, gravity is pulling them together. However, as the universe continues to expand, the effect of dark energy becomes stronger and eventually overpowers gravity, causing the expansion to accelerate.
4. Will the expansion of the universe ever stop?
There is currently no evidence to suggest that the expansion of the universe will ever stop. In fact, observations show that the expansion is actually accelerating. However, there are some theories that suggest that the expansion could eventually slow down or reverse in the far future, but this is still a topic of ongoing research.
5. How does the concept of an expanding universe relate to the Big Bang theory?
The Big Bang theory states that the universe began as a single point and has been expanding ever since. The concept of an expanding universe is a key component of the Big Bang theory, as it explains the observed redshift and cosmic microwave background radiation. However, the Big Bang theory also includes other important aspects such as the inflationary period and the formation of galaxies and stars.
  • Astronomy and Astrophysics
