Doubt with power of lens with 2 media
In summary: Using the correct formula will give you the correct focal length. In summary, the focal length of a biconvex lens with refractive index n2, bounded by media of RI n1 and n3, can be found using the formula 1/f = (n2/n1 - 1)/R1 + (n2/n3 - 1)/R2, where R1 and R2 are the radii of curvature of the lens. This takes into account the different powers of each surface of the lens.
sachin123
121
This is more of a general question.
Suppose there is a biconvex lens(Radii are R1 and R2) with Refractive index =n2,it is bounded on 2 sides by media of RI=n1,n3.
Now if I have to find its focal length,
1/f=(n2-n1)/R1+(n2-n3)/R1.
Is it correct?
Suppose it were correct,
If there is a biconvex lens with radii of curvatures R,with refractive index(RI)=n2 and surrounded by medium of RI=n1,then its power is,(n2/n1-1)(2/R)(Lens maker formula).Correct?
But if we consider individual surfaces and use Power=(n2-n1)/R for 1rst and (n1-n2)/R for the second surface,and add them,I get Power=(n2-n1)(2/R).The two are different.
Now where did i go wrong?
Wrong?
Or should it be used like(I read in many places):
1/f=((n2/n1)-1)/R1+((n2/n3)-1)/R1.
or
1/f=((n2/n1)-1)/R1+((n3/n2)-1)/R1.
Please explain.
I am seriously confused:(.
I would explain more if didn't understand.
Thanks
. The correct formula to find the focal length of a biconvex lens with refractive index n2, bounded by media of RI n1 and n3, is: 1/f = (n2/n1 - 1)/R1 + (n2/n3 - 1)/R2. This is because the power of a lens is given by (n2/n1 - 1)(2/R) where R is the radius of curvature of the lens. In this case, each surface of the lens has a different power, so you need to add the powers of each surface to get the total power of the lens.
Related to Doubt with power of lens with 2 media
1. What is the power of a lens?
The power of a lens is a measure of its ability to bend light. It is expressed in diopters (D) and is determined by the curvature and thickness of the lens.
2. How is the power of a lens affected by the media it is placed in?
The power of a lens is affected by the refractive index of the media it is placed in. A higher refractive index will result in a greater power, while a lower refractive index will result in a lower power.
3. What is the relationship between the power of a lens and the focal length?
The power of a lens is inversely proportional to its focal length. This means that a lens with a higher power will have a shorter focal length, and vice versa.
4. How does the power of a lens change when light passes through two different media?
When light passes through two different media, the power of a lens will change due to the change in refractive index. This is known as refraction and is the basis for how lenses work.
5. Can the power of a lens be adjusted?
Yes, the power of a lens can be adjusted by changing the curvature or thickness of the lens. This can be done through various methods such as changing the shape of the lens or adding a coating with a different refractive index.
