marcophys
- 152
- 20
Just watched many times (specifically @ 20:13 - 25:04) Ron Garret's 'Google Tech Talk'
All was going well - the 2 photon experiment & concept visualised - only that the finality of comprehension wasn't delivered... perhaps because Ron was merely using this for his own purpose.
This seems a shame because it looks to offer a very understandable explanation of entanglement.
So... have I understood this correctly?
... a UV photon enters the crystal, excites an electron to jump... as it falls back down, during the descent, at:
Point 'x' a photon is emitted
I get this... it sounds similar to night vision scopes (but probably isn't), but I get how the two photons are produced, and of course, I believed it when he states that these are somehow paired up - presumably entangled.
Sadly he then began to ramble on... but my interpretation is that we now have:
the 'x' produced photon, and the 'y' produced photon, head off on two different bearings.
One photon (say x) heading leftwards... the other photon (say y) heading rightwards.
Have I understood correctly?
If we place a photon detector in the path of (say) the left photon (x), and absorb it... the right photon (y) instantaneously either:
ceases to exist
or
changes it's state
The concept being that, even if the two photons are separated by a million kilometres, the right photon will change instantly ie. indicating faster than light transmission of data.
This last element is stated clearly, and is apparently incontrovertible, only...
... Ron then again rambles on about communicating through time, so this is impossible etc etc.
The explanation ends @ 25:04
Note: Ron points out that this can't be used as a means of communication due to randomness, but the explanation 'fizzles out' with: the supposed detector guy in space having seen a photon, and we've seen a photon, but we've not transmitted any information and...... (ha ha ha, nudge nudge, wink wink)
The final remarks are 'kind of' thrown away with a shrug, like as if it is anyway obvious.
Okay... so I believe him... we can't use this as a means of transmitting data.
Only that the rambling closure to this explanation clouds the concept of something physically happening:
Two photons, created as described, can influence each other instantaneously regardless of distance.
Is this the case, as a physical fact?
Thoughts:
If this IS the case, it follows, as a physical fact, that there is a 'data comms connection' between x & y photons.
That being a comms connection of type...
I think I'll stop there and stick to what we do know
a short time later, the electron descends further to:
Point 'y' a second photon is emitted.I get this... it sounds similar to night vision scopes (but probably isn't), but I get how the two photons are produced, and of course, I believed it when he states that these are somehow paired up - presumably entangled.
ceases to exist
or
changes it's state
Thoughts:
