Xenekaro
- 6
For the motion of a spherical ball under water, can its drag force be calculated by knowing only its mass and deceleration?
Xenekaro said:ok awesome. I thought F=ma was only valid for terminal velocity so I was wondering about the drag equation.Thanks again guys!
boneh3ad said:No. The mass times the acceleration in this case will give you drag minus weight (draw a free body diagram). You will have to add the weight to the net force to get the drag.
Xenekaro said:I find the drag force calculations to be too simple to actually warrant the need to formulate the more complex drag equation. I mean why worry about drag coefficient if you can calculate the drag just by knowing the object's mass and deceleration rate.
Drag force is a force that opposes the motion of an object through a fluid, such as air or water. It is caused by the interaction between the object and the molecules of the fluid.
The drag force on an object can be calculated using the formula: Drag force = 1/2 * density * velocity^2 * drag coefficient * surface area. The drag coefficient and surface area depend on the shape and size of the object, while density and velocity are properties of the fluid.
The drag force on an object is directly proportional to its mass. This means that as the mass of the object increases, the drag force also increases.
Deacceleration, or the decrease in velocity, increases the drag force on an object. This is because as an object slows down, there is less kinetic energy to overcome the resistance of the fluid, resulting in a higher drag force.
The drag force on an object can be affected by several factors, including the density and viscosity of the fluid, the shape and size of the object, and the velocity of the object. Other factors such as surface roughness and turbulence can also impact drag force.
