Drawing Graphs: Concentric Circles & Straight Lines
In summary, the first graph would be concentric circles with the center at (0,0) and the second graph would be straight lines through (0,0). For ln(0) = constant in the first graph, it is not possible as x=y=0 is never a solution. For x = 0 in the second graph, the slope would be tan(constant) and the graph would be a straight line through the origin.
Raees
Hi, how would I go about drawing these two graphs?
and
The first one would be concentric circles with the centre at (0,0).
The second one would be straight lines through (0,0).
Is this correct?
Also, what happens at ln(0) = constant for the first graph and x = 0 for the second graph?
[Moderator's note: Moved from a technical forum and thus no template.]
Correct.
That is not possible. x=y=0 is never a solution. Same for x=0 in the second case.
For "interesting" functions f(x)=constant usually means x has one or a somewhat special set of values for a given constant. If f is injective then it is equivalent to x=constant.
For the first one, [itex]ln(x^2+ y^2)= constant[/itex], taking the exponential of both sides, [itex]x^2+ y^2= e^{constant}[/itex]. Yes, the graph of that is a circle with center at the origin and radius [itex]\sqrt{e^{constant}}[/itex].
For the second one, [itex]arctan(y/x)= constant[/itex], taking the tangent of both sides, [itex]y/x= tan(constant)[/itex] so [itex]y= (tan(constant))x[/itex]. Since the tangent of a constant is also a constant, this is a straight line through the origin with slope tan(constant).
Thanks, that helps a lot!
Related to Drawing Graphs: Concentric Circles & Straight Lines
1. How do I draw concentric circles?
To draw concentric circles, you will need a compass or a circle-drawing tool. Place the point of the compass at the center of your paper and adjust the other end to the desired radius. Then, rotate the compass around the center point to create a circle.
2. How do I create evenly spaced concentric circles?
To create evenly spaced concentric circles, you can use a ruler to measure and mark the desired distance between each circle. Alternatively, you can use a compass with multiple settings or a circle-drawing tool with adjustable measurements.
3. How do I draw straight lines between the concentric circles?
To draw straight lines between the concentric circles, you can use a ruler or a straight edge to connect the points where the circles intersect. Alternatively, you can use a protractor to measure and draw the lines at specific angles.
4. How can I make the concentric circles and straight lines more accurate?
To make the concentric circles and straight lines more accurate, you can use a higher quality compass or circle-drawing tool. You can also use a ruler with smaller increments or a protractor with more precise measurements.
5. Is there a specific mathematical equation or formula for drawing these graphs?
Yes, there is a mathematical equation for drawing concentric circles. It is x² + y² = r², where x and y represent the coordinates of the circle's center and r represents the radius of the circle. For straight lines, the equation is y = mx + b, where m is the slope of the line and b is the y-intercept.
