kihr
- 102
I would request for help in understanding why the drift speed of electrons in semiconductors is more than that of holes. Thanks.
marcusl said:A free electron (in the conduction band) can travel through the bulk semiconductor. It of course scatters off of atoms in the crystal lattice, resulting in the slow net motion known as drift.
It is a bit more difficult for a hole to drift, because a leapfrog action is required. An electron "upstream" of the hole must be excited to the conduction band, drift "downstream", and recombine with that hole. It leaves behind the hole from the atom where it was excited, however, so it looks like the hole has moved upstream. Now the process can repeat, and the hole continues to drift.
Because an electron must happen upon and recombine with a hole, this process happens more slowly (with lower probability) than electron drift. We say that the hole's mobility is lower than the electron's. Because the mobility is lower, a hole has a lower drift velocity in a given applied electric field than an electron.
The drift speed of electrons and holes in semiconductors refers to the average speed at which these charge carriers move through a semiconductor material when subjected to an electric field. It is typically measured in meters per second (m/s).
The drift speed of electrons and holes in semiconductors is directly proportional to temperature. This means that as temperature increases, the drift speed also increases.
The drift speed of electrons and holes in semiconductors can be affected by the strength of the electric field, the type of material, the temperature, and the presence of impurities or defects in the material.
The drift speed of electrons and holes is directly related to the electrical conductivity of a semiconductor material. As the drift speed increases, the material becomes more conductive, allowing for the flow of electric current.
Yes, the drift speed of electrons and holes in semiconductors can be controlled by adjusting the electric field strength, temperature, and the type and concentration of impurities in the material. This is an important aspect in the design and function of electronic devices such as transistors and diodes.
