Pressure Difference in a Drinking Straw
  • Thread starter Zanathyne
In summary, the conversation revolves around a question in fluid statics and the confusion about the forces involved in the scenario of dipping a straw into a liquid and holding your finger over the top. The equations used to calculate the pressure at the bottom and top of the straw are discussed, but an error is found in the reasoning. It is clarified that there are actually three forces at play - the pressure at the bottom, the pressure at the top, and the force caused by the mass of the water. This leads to the understanding that these forces are in equilibrium and provides a clearer explanation of the scenario. Overall, the conversation highlights the importance of considering all forces involved in a given situation.
Zanathyne
Hi, firstly allow me to say that this is not a homework question but the question fits mostly in the introductory physics section. I’m sorry if this is truly the wrong section for my question. Please direct me to right section and I will delete this thread from this section immediately. The question is just something I’ve been pondering and I would like for someone to help me figure out where I’m going wrong.
It’s a fluid static’s question I guess. I’ve been thinking about the old dipping a straw into a liquid and then holding your finger over the top, and then you extract the straw and the fluid remains inside. Of course the pressure at the top is lesser than the pressure at the bottom where the pressure at the bottom is atmospheric pressure. Using some equations I get:
Where Pb = Pressure at the bottom,
Pt = Pressure at the top,
Po= atmospheric pressure,
D = density of the fluid,
g = gravitational acceleration,
h = length of the colunm of fluid in the straw
Pb = Pt + Dgh
Pb =Po
Po= Pt +Dgh
So
Pt = Po - Dgh
The pressure at the top is lesser than the pressure at the bottom by Dgh, which makes sense.
But this is where I become confused and the math doesn’t add up.
First I’m thinking that since the water is at rest that means it is at equilibrium so the net force is zero, gravitational force = the buoyant force (I assume the force acting upward is the buoyant force)
Where A= cross sectional area of the straw (equal everywhere; meaning the straw is just a straight tube)
Ft =force acting downwards on the top of the straw
Fb = force acting upwards on the bottom of the straw
Fg = gravitational force
Fbo = buoyant force
First:
Ft = Fg
Fb = Fbo
Since they are in equilibrium:
Fbo = Fg
So Pb = Fbo/A
And Pt = Fg/A
Since Fg = Fbo
Then this must mean Pb = Pt
Which is incorrect!
To put it in plain words, the pressures differ by Dgh and since the areas are the same that means that the forces must differ (where Fb – Ft = ADgh = mg where m is the mass of the fluid causing a downward acceleration) but how can they differ if the net force = 0 which means the forces are equal. Can someone please help me out with this?
Fbo = buoyant force
First:
Ft = Fg
at this stage an error kreeps in ...
I would prefer if you would rather call the "bouyant force" the upwards force say Fu, since bouyancy has another meaning in physics. This force is caused by the atmospheric pressure on the bottom of the water column in the straw. It can be found by multiplying your eqaution
Pt = Po - Dgh
with A giving
APo = APt + ADgh - which can be written as APo = APt + mg via the density giving
Fu = APt + mg or Fu = Ft + mg
the first term gives Fu (or your Fbo). So you have missed a term in your reasoning - the force due to the air pressure on top of the liquid in the straw (I chose Ft for the force caused by this air pressure).
Pt = Po - Dgh
with A giving
Thanks for responding to my thread. I see where I went wrong! This says there are three forces not two as I first believed, those being the forces brought on by the pressure at the bottom and the pressure at the top and the one that I can't believe I missed (although I stated it) the force caused by the mass of the water! ha ha :smile: so these three forces are in equilibrium, from your equation:
Fu = Ft + mg
Fu - Ft - mg =0
perfect sense. Thanks.
It's a pleasure.
Related to Pressure Difference in a Drinking Straw
What is the purpose of a drinking straw?
A drinking straw is a small tube typically made of plastic or paper, used for transferring a beverage from its container to the mouth.
Why do some people prefer to use a drinking straw?
Some people prefer to use a drinking straw because it can help prevent spills and stains on clothing, as well as protect their teeth from contact with acidic or sugary drinks.
Are drinking straws harmful to the environment?
Yes, drinking straws can be harmful to the environment. Plastic straws are not biodegradable and contribute to pollution in oceans and landfills. Paper straws are a more eco-friendly option, but they still require resources to produce and can only be used once.
What are some alternatives to traditional plastic straws?
There are many alternatives to traditional plastic straws, including reusable stainless steel or glass straws, biodegradable paper straws, or even edible straws made from materials like pasta or seaweed.
How can I dispose of a drinking straw responsibly?
If you are using a plastic straw, make sure to properly recycle it if possible. If you are using a paper straw, it can be composted. Alternatively, consider using a reusable straw that can be washed and used again.
