Driven Harmonic Oscillator where Mass Hits Ground
In summary, the conversation discusses the dynamics of a driven, damped oscillator with a mass that is free to vibrate in the y-direction. The impact of a wall or ground on the oscillation is explored, and there is a question about how these non-elastic impacts affect the amplitude-frequency plot. It is mentioned that the natural frequency can be calculated when there is no impact, but the question arises if collisions with the wall alter the natural frequency and amplitude of the oscillation. The possibility of adding energy to the system is also mentioned, and it is suggested that the weight may fall out of phase with the natural frequency due to collisions. The conversation ends with a question about the effect of collisions on the amplitude-frequency plot.
Nefertiti
I started to ponder following problem. I have a driven, damped oscillator where the mass is free to vibrate in y-direction. If I put a wall or a ground near the mass, the mass touches it if the drive amplitude is larger than the distance to the ground. How does this change the normal dynamics. I would expect that the oscillation becomes pretty complex depending on forcing amplitude and spring parameters. Is it possible to derive the amplitude equation for given frequency and spring parameters?
It would depend on how elastic the collisions were.
Assuming massless springs, rigid weights, etc:
If the collisions were completely inelastic, the results would be fairly simple because the new velocity (zero) would not depend on the incident velocity.
Generally, on collision the velocity of the oscillating weight would change by a factor of "a" in the y direction where 0>=a>=-1.
Assuming inelastic collision, would it be possible to analytically derive the amount of energy transferred to the ground? Especially considering the spring parameters and the driving frequency.
If you know the frequency, it should be easy to model the system.
You really haven't described the whole system. Are you pumping energy into this system? What is causing the "damping", friction in the spring?, a function of the velocity?
If it's inelastic and you are not going to add energy to the system, it will hit the floor once and then never again.
I'm considering following scenario. The "ground" to which the spring is attached, is driven with n=C*Cos(wt). The natural frequency for this setup can be solved when there is no impact with the wall. Now I'm considering the case where there is an impact with the spring-mass and the wall. The impact should be inelastic but as the "ground" is driven, there is energy so that movement doesn't die out. The question is: is the amplitude-frequency plot altered by these non-elastic impacts?
If you look at the weight cycling at it's natural frequency, it will follow the sine function. If we consider the point when it is closest to the wall to be the 0-degree and 360-degree position, then what happens when it hits the wall will be that it will suddenly skip from a position such as 350 degrees to the 0 degree position.
Thus the new "natural frequency" will be higher and will be dependent on how much energy is added on each cycle.
If the w in the C cos(wt) is not changed, the collision will cause the weight to fall out of phase with N. So if the w is kept at the original natural frequency, a series of collisions (a series could be just one collision) will put the weight sufficiently out of phase that the weight will not efficiently increase the amplitude. Then the system will begin to recover - eventually bringing the weight into phase and increasing the amplitude thus setting it up for the next series of collisions.
Related to Driven Harmonic Oscillator where Mass Hits Ground
1. What is a driven harmonic oscillator where mass hits ground?
A driven harmonic oscillator where mass hits ground is a physical system in which a mass is attached to a spring and is subjected to a driving force. The mass oscillates back and forth due to the restoring force of the spring and the driving force. When the mass hits the ground, it experiences a sudden change in velocity and direction, resulting in a change in the oscillation behavior.
2. What factors affect the behavior of a driven harmonic oscillator where mass hits ground?
The behavior of a driven harmonic oscillator where mass hits ground is affected by several factors, including the mass of the object, the stiffness of the spring, the frequency and amplitude of the driving force, and the initial conditions of the system. These factors can determine the amplitude, frequency, and phase of the oscillations.
3. How does the driving force affect the motion of the mass in a driven harmonic oscillator where mass hits ground?
The driving force in a driven harmonic oscillator where mass hits ground can either increase or decrease the amplitude of the oscillations, depending on whether it is in or out of phase with the natural frequency of the system. If the driving force is in phase with the natural frequency, it will add energy to the system and increase the amplitude. If it is out of phase, it will subtract energy and decrease the amplitude.
4. What happens when the mass hits the ground in a driven harmonic oscillator?
When the mass hits the ground in a driven harmonic oscillator, it experiences a sudden change in velocity and direction, resulting in a change in the oscillation behavior. The kinetic energy of the mass is converted into potential energy as the spring is compressed, and then it is released, resulting in an increase in amplitude and a phase shift in the oscillation.
5. How does the mass affect the behavior of a driven harmonic oscillator where mass hits ground?
The mass in a driven harmonic oscillator where mass hits ground affects the frequency and amplitude of the oscillations. A larger mass will result in a lower natural frequency and a smaller amplitude, while a smaller mass will have a higher natural frequency and a larger amplitude. The mass also affects the energy transfer between kinetic and potential energy during the oscillations.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Quantum Physics
  • Classical Physics
