Dropped popcorn kernel from space will it pop?
In summary, the question of whether a corn kernel would pop during re-entry from space was posed to Popular Science in Jan 2009. The question was not fully answered, but it was suggested to consider the conditions in which a kernel of popcorn typically pops and whether those conditions could be achieved during re-entry or in space. It was also noted that heat is a likely factor in causing a kernel to pop, but it is uncertain if the speed of falling corn during re-entry would be enough to generate sufficient heat.
LionTigerFire
"If You Dropped a Corn Kernel From Space, Would it Pop During Re-Entry?"
This wacky question way emailed to the magazine Popular Science insufficiently answered in Jan 2009 p.80
is it possible to figure mathematically this out without testing it
Astronomy news on Phys.org
First ask - under what conditions does a kernel of popcorn pop, i.e. what causes a kernel to pop?
Then ask, can a kernel of popcorn achieve these conditions during re-entry, or even in space, given the available sunlight and vacuum conditions?
"First ask" - I'm going to guess heat causes sufficient pressure inside the kernel.
During atmospheric re-entry it gets pretty hot. Would the kernel vaporize or just burn instead of pop?
Would the falling corn actually have enough speed to get hot during re-entry though?
Related to Dropped popcorn kernel from space will it pop?
1. Will a dropped popcorn kernel from space actually pop?
Yes, it is possible for a dropped popcorn kernel from space to pop. However, it is not guaranteed as several factors, such as atmospheric pressure and temperature, can affect the popping process.
2. How high does the popcorn kernel need to be dropped from for it to pop?
The height from which a popcorn kernel needs to be dropped for it to pop depends on several factors, such as the density, temperature, and pressure of the surrounding atmosphere. However, it is generally believed that the kernel needs to be dropped from at least 30,000 feet (9,144 meters) for it to pop.
3. What happens to the popcorn kernel during its descent from space?
As the popcorn kernel falls through the Earth's atmosphere, it experiences a decrease in air pressure and an increase in temperature due to the friction with the air molecules. This causes the moisture inside the kernel to turn into steam, eventually building up enough pressure to burst the kernel and create the familiar "pop" sound.
4. Can a microwave popcorn bag pop in space?
No, a microwave popcorn bag cannot pop in space because it requires a microwave to heat the kernels and create the necessary pressure for them to pop. In the absence of a microwave, the kernels will not pop even if they are in space.
5. Can a dropped popcorn kernel from space be edible?
It is possible for a dropped popcorn kernel from space to be edible, but it is not recommended. The extreme temperatures and atmospheric conditions during its descent may affect the quality and safety of the popped kernel, making it potentially harmful to consume.
