Dropping and launching space shuttles
  • Thread starter WarnK
  • Tags
    Space
In summary, if two identical shuttles were launched and dropped at the same time, the one falling towards the ground would likely reach its destination first due to a greater acceleration towards the ground.
WarnK
31
Take two identical of those nice NASA space shuttles and at the same time as you launch one you drop the other from its orbit around earth. What happens first? Do the one going up reach orbit before the one falling hits the ground?
There's a nice little thread about the shuttles acceleration here:
https://www.physicsforums.com/showthread.php?t=224305
But I have no idea. Any ideas are welcome, thanks!
The two situations are not particularly comparable. As it starts its way into orbit, the Shuttle is accelerating at several gravities and gaining velocity more than altitude. On the way back from orbit, the Shuttle is using atmospheric braking to shed most of that velocity, after using a smaller maneuvering thruster burn to change its orbit to dip into the atmosphere, and then gliding to a runway. A Shuttle dropped from a relative halt at orbital altitude would hit ground sooner, but this doesn't resemble anything the Shuttle ever actually does. The specifics of how long it'd take would be non-trivial to calculate and would also depend on how the Shuttle was oriented during reentry and flown once in the atmosphere, and would also not hold much meaning.
It's a very interesting question! According to the thread you linked, the acceleration of the space shuttle is around 3g (3 times the acceleration due to gravity). So, if we assume that the shuttle is dropped from a low orbit around Earth, it would experience an acceleration of approximately 3g towards the ground.
On the other hand, the shuttle that is launched would experience an acceleration of around 1g (due to Earth's gravity) and also an additional acceleration due to the thrust of its engines. However, this acceleration would be much smaller compared to the 3g acceleration of the falling shuttle.
Therefore, it is likely that the falling shuttle would reach the ground first, since it is experiencing a greater acceleration towards the ground. However, this also depends on the initial altitude and speed of the shuttle before it is dropped. If the shuttle is dropped from a higher orbit, it may take longer to reach the ground compared to the shuttle that is launched.
In any case, both shuttles would eventually reach their respective destinations (ground and orbit) at different times. It's a fascinating thought experiment and would be interesting to see in action (although I hope it never actually happens!).
Related to Dropping and launching space shuttles
1. How does NASA determine the best time to launch a space shuttle?
NASA uses a complex system of mathematical calculations and computer simulations to determine the optimal launch window for a space shuttle. Factors such as the position of the Earth and its rotation, weather conditions, and the desired orbit of the shuttle all play a role in the decision-making process.
2. What safety measures are in place during a space shuttle launch?
Before a space shuttle is launched, it undergoes rigorous testing and inspection to ensure that all systems are functioning properly. During the actual launch, there are numerous safety protocols in place, including emergency escape systems, redundant backup systems, and a team of trained personnel monitoring the shuttle at all times.
3. How does gravity affect a space shuttle during launch?
The force of gravity plays a crucial role in the launch of a space shuttle. As the shuttle gains altitude, it must overcome the pull of Earth's gravity to continue its ascent. This is achieved through a combination of powerful engines and the aerodynamic design of the shuttle's external tank and solid rocket boosters.
4. What happens to a space shuttle after it is dropped from the external fuel tank?
Once the space shuttle has reached the desired altitude and velocity, it separates from the external fuel tank and continues its journey into orbit. The fuel tank, which is no longer needed, falls back to Earth and burns up in the atmosphere. The space shuttle then uses its own thrusters to adjust its trajectory and reach its final destination.
5. How does NASA retrieve a space shuttle after it lands?
After a successful mission, the space shuttle re-enters Earth's atmosphere and lands at a designated site, typically at the Kennedy Space Center or Edwards Air Force Base. Once it has landed, a team of trained technicians and engineers conduct a thorough inspection of the shuttle and prepare it for its next mission.
  • Aerospace Engineering
  • Art, Music, History, and Linguistics
9K
