Dsa -- Two masses orbiting their barycenter
  • Thread starter Thread starter antythingyani
    Two masses
In the discussion, two masses, m1 and m2 (where m2 = a.m1 and m2 > m1), are analyzed for their orbital dynamics around a barycenter. The primary question focuses on determining the relative speed of the masses needed for m1’s orbit to exhibit cusps while the barycenter moves at speed v in an inertial frame. Participants emphasize the necessity for the original poster to provide calculations or equations to facilitate assistance. The thread was locked after the OP attempted to delete their post following the request for additional work. The conversation highlights the importance of showing work in physics discussions to receive meaningful help.
antythingyani
Do NOT delete your original post after you have received replies
frs
R1 = (m2/(m1+m2))r
Two bodies with masses m2 and m1, m2=a.m1 and m2>m1 orbit each other in circular orbits. if the barycenter moves at a speed v with respect to an inertial reference frame, What should be the relative speed of the bodies so that m1’s orbit in this inertial frame will have cusps?
You need to show some work before we can offer assistance. You could begin by adding some additional relevant equations.
Likes berkeman
Mentor Note -- OP tried to delete their post after receiving the reply that they need to show their work first. The OP text has been restored and the thread is now locked.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
