DSC Polymer Characterisation interpretation help
In summary: Knowledge :)Good evening Kevin McHughThank you for your further clarification. I shall definitely integrate the small enthalpy peak.Kind regards
Seeker3
Hi respected peers,
Firstly, i must apologise in advance for any error i may make within this forum, I'm a new member here.
The question i wish to ask is with regards to observing a glass transition and crystallisation peak upon cooling, however without observing the obvious melt of a polymer being investigated. Is that possible?
I believe in theory you must have a melt peak before seeing crystallisation peak. However I am not an expert in this field to interpret such characteristics. The polymer investigated is a chemically synthesised dimercaptodithiin subsituted polyfuran. Powder XRD shown a small sharp peak at 10 A suggesting crystalline character.
In truth i am seeking an experts opinion to provide a little insight on how to correctly describe such a polymer. The glass transition and crystallisation peaks are prevalent in each consecutive heat-cool-heat cycles until degradation temperature has exceeded. Please find attached thermal history DSC graphs attached.
Any advice or further information would be highly appreciated.
Thank you kindly
  • IMG_4600.pdf
Chemistry news on Phys.org
You don't have much going on there in terms of thermal events. It is very difficult to tell which is the first heat history and the last cycle. The only consistent thing I see is an exothermic event < 100o C. Probably a Tg. But it does not appear your polymer has much crystallinity (if any). If you ran subsequent heat histories, with the first going up to 400o C, the polymer has degraded, and any data after that us useless. I did see one endothermic peak. Integrate that peak to determine ΔH of fusion. Repeat several times to see if the the event is reproducible.
Likes Seeker3
Good afternoon Kevin McHugh
Firstly, thank you kindly for taking your time out to check over my DSC graph traces and providing your valuable input. The thermal cycles provided were performed in four cycles with the methodology being;
First Run -50 to 150 degrees
Second Run-50 to ~180 degrees
Third run was from -50 to 300
Then last run from -50 to 400
I have attached a second run, in which i do the first cycle upto 125 degrees to remove any thermal histroy associated with the polymer. Then second cycle is ramped upto 275 degrees past polymer degradation.
I feared i had incorrectly assumed glass transition temp and upon cooling cycling a crystallisation peak. Therefore, for conclusion of these DSC graphs, I am unable to determine much thermal transitions of the polymer besides degradation temperature, possible Tg before 100 degrees and upon cooling the endothermic peak (which i assumed was polymer crystalline peak, but enthalpy of fusion?)Thank you again
Seeker of Knowledge :)
  • DSC PolythienylFuran thermal graph-1.pdf
Definitely no crystallinity in that polymer. You should integrate the small peak to determine ΔH at that point, Still very small enthalpy.
Likes Seeker3
Kind regards
Seeker
FAQ: DSC Polymer Characterisation interpretation help
What is DSC Polymer Characterisation?
DSC (Differential Scanning Calorimetry) Polymer Characterisation is a technique used to measure the thermal properties of polymers. It involves heating a sample of the polymer and measuring the heat flow as a function of temperature. This can provide information about the polymer's melting point, glass transition temperature, and other thermal transitions.
How can DSC Polymer Characterisation be interpreted?
Interpretation of DSC Polymer Characterisation data involves analyzing the heat flow curves and identifying any thermal transitions that occur. This can be done by comparing the data to known standards or by using software to analyze the data. It is also important to consider the sample preparation and any other factors that may affect the results.
What are the benefits of DSC Polymer Characterisation?
DSC Polymer Characterisation is a valuable tool for understanding the thermal behavior of polymers. It can provide information about the polymer's stability, purity, and processing conditions. It is also a quick and non-destructive method, making it ideal for quality control and research purposes.
What are some common challenges in interpreting DSC Polymer Characterisation data?
One of the challenges in interpreting DSC Polymer Characterisation data is the presence of multiple thermal transitions, which can be difficult to distinguish and analyze. Another challenge is the potential for sample degradation during the heating process, which can affect the results. It is important to carefully consider these factors when interpreting the data.
How can I use DSC Polymer Characterisation data in my research?
DSC Polymer Characterisation data can be used in a variety of ways in research. It can help in the development of new polymers or in understanding the properties of existing ones. The data can also be used to compare different samples or to monitor changes in a polymer over time. Additionally, DSC Polymer Characterisation can be used to study the effects of additives or processing conditions on the thermal behavior of polymers.
17K
