DSP, going from freq domain to time domain
In summary, converting from frequency domain to time domain in DSP allows for the analysis and processing of signals in the time domain, which can provide valuable information about the signal's behavior over time. This is achieved through the use of the inverse Fourier transform, which can transform a signal from the frequency domain back to the time domain. Working with signals in the frequency domain has advantages such as clearer understanding of frequency components and more efficient processing, but there may be some loss of information in the conversion. It is necessary to convert from frequency domain to time domain in DSP when tasks such as filtering or noise reduction require information about the signal's behavior over time.
cutesteph
63
X(w) = 3cos(2w) + 2 sin(3w)
calculate x(n)
x(n) = (1/2pi) ∫ X(w) e^(jwn)dw
When integrating over 0 to 2 pi, my answer is 0. Which would not be the case.
Can you please show your calculation? In particular, be careful with the cases ##n=2## and ##n=3##.
It for sure shouldn't be 0 :D
You must've made a mistake with the integration. Do you know what the answer SHOULD be?
Related to DSP, going from freq domain to time domain
1. What is the purpose of converting from frequency domain to time domain in DSP?
The purpose of converting from frequency domain to time domain in DSP is to analyze signals in the time domain, which can provide information about the behavior and characteristics of the signal over time. This can be useful for tasks such as filtering, noise reduction, and signal processing.
2. How is the conversion from frequency domain to time domain performed in DSP?
The conversion from frequency domain to time domain in DSP is accomplished using the inverse Fourier transform, which is a mathematical operation that can transform a signal from the frequency domain back to the time domain. This can be done using various techniques such as Fast Fourier Transform (FFT) or Discrete Fourier Transform (DFT).
3. What are the advantages of working with signals in the frequency domain vs. the time domain?
Working with signals in the frequency domain allows for a clearer understanding of the frequency components present in the signal, which can aid in the identification and removal of noise or other unwanted signals. It also allows for more efficient processing of signals, as certain operations such as filtering can be performed more easily in the frequency domain.
4. Can converting from frequency domain to time domain result in any loss of information?
Yes, converting from frequency domain to time domain can result in some loss of information. This is because the time domain representation of a signal may not capture all of the frequency components present in the original signal. However, this loss of information can be minimized by using appropriate techniques and ensuring that the sampling rate is high enough to accurately capture the signal's frequency components.
5. In what situations is it necessary to convert from frequency domain to time domain in DSP?
Converting from frequency domain to time domain is necessary in DSP when the desired analysis or processing task requires information about the signal's behavior and characteristics over time. For example, if a signal needs to be filtered or noise needs to be removed, it is necessary to convert to the time domain to perform these tasks effectively.
