Du Nouy Method for Measurement of Surface Tension
In summary: If there were no adhesive forces between the ring and the liquid, outer force (no matter how small) would immediatelly tore it from the surface regardless of surface tension of the liquid.In summary, the surface tension of liquid can be determined by force balance acting on the ring placed on the liquid surface.
Dario56
290
45
This method calculates surface tension based on force balance acting on the ring placed on the liquid surface: $$ F = G + \gamma L $$
where ##G## is weight of the ring, ##L## is wetted length of the ring which is equal to its circumference, ##F## is outer force of tensiometer acting on the ring
So, when force balance is reached by changing outer force, ring is ripped off from the surface and surface tension can be calculated.
However, if this is so, what does surface tension of liquid have to do with force acting on the ring since adhesion between ring and liquid is what resists ring being ripped of from the surface not surface tension of the liquid?
Please articulate your understanding of the term surface tension.
Work needed to expand surface of the liquid per unit area. In most general terms, surface energy can be defined for any surface and interphase, but here we determine surface tension of interphase liquid/air.
This is not ideal as we would want to determine surface energy in a vacuum because any medium (in our case air) stabilizes the surface of the liquid by adhesion and adsorption.
This is somewhat consistent with the definition of surface tension I am accustomed to be working with: in-plane normal tensile force per unit length along any contour within the surface. Are you comfortable with this definition?
Chestermiller said:
This is somewhat consistent with the definition of surface tension I am accustomed to be working with: in-plane normal force per unit length along any contour within the surface. Are you comfortable with this definition?
Well, I do know that surface tension can be defined as force per unit of length where length is some constant dimension connected to change in area. This can be seen in example on wikipedia. I am not completely comfortable with definition you used, where can I study it more?
I don't have any book references. I learned this a long time ago in course work, and it has never failed to deliver. I strongly encourage you to learn about it. It is very simple to apply, as in the example of the Du Nuoy ring that you cited.
hutchphd said:
My way into thinking about it was the Laplace-Young equation
The Laplace-Young equation can be derived from the definition I gave for the case of a curved surface.
Likes hutchphd
I was recommending it and its derivation as a means of understanding tensile strength as force per length. It helped me.
I do understand N/m interpretation which is usually tought (there is example on wikipedia), that interpretation is equivalent to J/m2 since length in N/m is really only parameter of the surface area.
Isn't tensile strength measured in [Pa] = [N/m2]?
Likes hutchphd
Surface energy, the potential energy resulting from the surface tension. The surface tension opposes an increase in the surface area. In order to enlarge the surface by an amount ##\Delta A##, an amount of work ##\Delta W## is required. The ratio of the work ##\Delta W## to the surface increase ##\Delta A##, is called the surface tension ##\sigma##:
##\sigma = \frac { \Delta W } {\Delta A }##
##\sigma = \frac { Delta W } {\Delta A }##
It doesn't really answer my question.
I would like to see what your sketch looks like for the water and ring when the upward force has been applied to the ring.
Yes. But what has "tensile strenght" to do with "surface tension"?
We have stemmed away from my original question which is that adhesion between ring and the liquid is what keeps the ring on the surface not surface tension of the liquid.
If there were no adhesive forces between the ring and the liquid, outer force (no matter how small) would immediatelly torn it from the surface regardless of surface tension of the liquid.
It will be the weakest link in the chain...could be adhesion or it could be tensile strength of the liquid surface I think. If the ring comes off "wet" I think it is probably not the adhesion.
Likes Lord Jestocost
Of course, one needs adhesion between the liquid and the ring in order to be able to enlarge the liquid’s surface when pulling out the ring. The work done to pull out the ring is related to the corresponding increase in the liquid's surface energy.
Du Noüy ring method | KRÜSS Scientific - Kruss
Yes, however force balance is written for the ring not the liquid. Adhesion is the force acting on the ring not surface tension. Surface tension acts on the liquid to minimize its surface area.
I think the point is that the air water interfaces at the inner and outer radii of the ring are essentially vertical when the failure occurs. I don't think that the upward force applied to the ring is varying substantially as this point is approached.
If adhesion is the mere force acting on the ring, why does the force which you have to apply to pull the wetted ring out of the liquid increases with distance between the ring and the liquid?
Surface tension measurement by Du Noüy ring method
It's definitely not adhesion that causes the ring to break loose. It is a hydrodynamic instability caused by the liquid film breaking apart. We know this because there is residual water on the ring after the failure of the film.
Likes Dario56 and Lord Jestocost
Interesting. This isn't mentioned anywhere where this method is described. What does hydrodynamic instability have to do with surface tension?
I think you wanted to point out to the Plateau–Rayleigh instability.
You are dealing with a fluid bounded by a free surface, right? Small perturbations to the shape of the surface and to the film itself (due to any type of fluctuation, such as a tiny vibration of the room or an air current) can either be damped out (by the viscous nature of the fluid) or amplify, depending on how much the film has been thinned out. If they amplify, the film will break apart. This is what happens when soap bubbles break apart.
FAQ: Du Nouy Method for Measurement of Surface Tension
What is the Du Nouy Method for Measurement of Surface Tension?
The Du Nouy Method is a technique used to measure the surface tension of liquids. It involves measuring the force required to lift a ring or plate from the surface of the liquid, which is then used to calculate the surface tension.
How does the Du Nouy Method work?
The Du Nouy Method works by using a tensiometer, which is a device that measures the force needed to lift a ring or plate from the surface of a liquid. The force is then converted into surface tension units using a calibration factor.
What are the advantages of using the Du Nouy Method?
One of the main advantages of the Du Nouy Method is its simplicity and accuracy. It is a relatively easy technique to perform and does not require expensive equipment. It also has a high level of precision, making it a reliable method for measuring surface tension.
What are the limitations of the Du Nouy Method?
The Du Nouy Method is limited to measuring the surface tension of liquids only. It cannot be used for measuring the surface tension of solids or gases. Additionally, the accuracy of the results can be affected by factors such as temperature, impurities in the liquid, and the shape and size of the ring or plate used.
Are there any alternative methods for measuring surface tension?
Yes, there are several alternative methods for measuring surface tension, such as the Wilhelmy Plate Method, the Pendant Drop Method, and the Capillary Rise Method. Each method has its own advantages and limitations, and the choice of method depends on the specific requirements of the experiment.
