Dual masters degrees beneficial?
In summary, the speaker is considering pursuing a dual masters degree in physics and mathematics, but has concerns about the overlap and potential lack of advantage in pursuing a PhD or career outside of academia. They are seeking opinions on whether a double major in these areas is beneficial or if they should broaden their studies with a bachelors degree in a different field. The speaker also mentions considering the financial and workload implications of such a decision.
Inve
Greetings PF.
I was thinking about going for a dual masters degree with one in physics and one in mathematics. Note that I'm not American, I'm currently in Europe and as such I'd guess it's almost like a double major. To me it felt like such a couple of degrees were a natural choice, but recently I've set myself under the impression that they are too "close" (no I'm not defining a metric) to each other such that the combination really does not give me an advantage if I wanted to pursue a PhD or if I'd give it a go outside academia. This closeness would make a rough cost/benefit analysis (workload, hours per week, etc) tell me that the cost is greater than the benefit.
I am currently in my senior years studying for a masters degree in physics. Because of reasons I have some extra time on my hands and thus this idea of a dual masters degree seems very doable. I realize a pice of information that is often wanted in dealing with these types of questions are "what do you want to do after you get your degrees?", and preferably I would give a definite answer but I'm at a loss since I want too much. But let's say it leans towards reaserch, both academic and private sector.
I'm curious of what the memebers here have to say about dual masters in these areas. Consider it a double major if that helps. Are they too close for any real benefit? Should one rather broaden with something like a bachelors degree in, say, CS or some EE?
Your thoughts please.
if i were you, i would ask myself:
-can i afford to pay the bill for such an endeavor?
-can i study and handle increased workload?
-am i at least 90% sure that i will succeed?
-will i have a few hours per week to cool down,ease the tention?
- will i be able to have a normal mentality or i will be torn apart?
-will that procedure of increased pressure burn me out?
if i could handle all the above i would do it,otherwise i would do one master,finish it,try to find a job,work for a while and make some money,later on pursue a second master.Pretty much that's what i might do :P
FAQ: Dual masters degrees beneficial?
What are the benefits of pursuing dual masters degrees?
One of the main benefits of pursuing dual masters degrees is that it allows you to gain expertise in two different fields, which can make you more versatile and marketable in the job market. Additionally, it can save time and money compared to pursuing each degree separately, and can also open up more career opportunities.
Is it difficult to balance the workload of two masters degrees at once?
Balancing the workload of two masters degrees can be challenging, but it is not impossible. It requires good time management skills and the ability to prioritize tasks. It may also be helpful to have a support system in place, such as classmates or professors, who can provide assistance or advice.
Are there any specific requirements for pursuing dual masters degrees?
The specific requirements for pursuing dual masters degrees may vary depending on the university or program. However, some common requirements may include a high GPA, letters of recommendation, and relevant work or research experience. It is important to research and carefully review the requirements of each program you are interested in.
Can I pursue dual masters degrees in any combination of fields?
While most universities offer a wide range of dual masters degree options, there may be some restrictions on certain combinations of fields. It is important to research and confirm that your desired combination of degrees is available at the university you are interested in.
Will having dual masters degrees give me an advantage in the job market?
Pursuing dual masters degrees can definitely give you an advantage in the job market. It shows that you have a diverse skill set and are capable of tackling multiple areas of expertise. It also demonstrates a high level of commitment and dedication to your education, which can be attractive to potential employers.
