MHB Dual Space .... Loring Tu, Section 3.1, page 19 .... ....
The discussion centers on Loring W. Tu's treatment of dual spaces in his book "An Introduction to Manifolds." Participants seek clarification on whether the basis vectors \( e_1, \ldots, e_n \) mentioned in Proposition 3.1 are intended to be a general basis or specifically the standard basis. It is confirmed that in the context of an arbitrary vector space \( V \), the basis is indeed general, as there is no standard basis applicable. The notation used does not imply a restriction to the standard basis, and examples illustrate that different bases can still yield similar coordinate representations. Overall, the conversation emphasizes the flexibility of basis selection in the discussion of dual spaces.
Math Amateur
MHB
I am reading Loring W.Tu's book: "An Introduction to Manifolds" (Second Edition) ...
I need help in order to fully understand Tu's section on the dual space ... ... In his section on the dual space, Tu writes the following:
View attachment 8792In the above text from Tu, just preliminary to Proposition 3.1 Tu writes the following:
" ... ... Let $$e_1, \ ... \ ... \ e_n$$ be a basis for $$V$$. ... ... "
Now my question is as follows:Is $$e_1, \ ... \ ... \ e_n$$ a completely general basis ... hence making Proposition 3.1 completely general (in terms of basis anyway) ... or given the notation is $$e_1, \ ... \ ... \ e_n$$ the standard basis where $$e_1 = ( 1, 0, 0, \ ... \ ... \ , 0 )^T , e_2 = ( 0,1, 0, \ ... \ ... \ , 0 )^T , \ ... \ ... \ , \ e_n = ( 0, 0, 0, \ ... \ ... \ , 1 )^T$$ ...I must say I can find no instance in the proof of Proposition 3.1 where the basis $$e_1, \ ... \ ... \ e_n$$ is assumed to be anything but completely general ... but would be appreciative if someone would confirm this to be the case ... ... ( ... hmmm ... pity Tu didn't use $$u_1, u_2, \ ... \ ... \ , u_n$$ as the basis for $$V$$ ... ... )My suspicions about the basis being not general ... but indeed the standard basis ... ... came about on reading the following note on page 11 concerning notation ...
View attachment 8793Hope someone can clarify the above ...
Help will be appreciated ...
Hi Peter,
Glad to hear you're taking a look at Tu, I think it's a good book on the subject.
When $V$ is an arbitrary vector space there is no such thing as the "standard basis;" i.e., the basis he selects is completely general. When working in $\mathbb{R}^{n}$ there is a standard basis; specifically, the unit vectors in the direction of the coordinate axes (see https://en.wikipedia.org/wiki/Standard_basis). In the case of the Proposition, Tu is just reusing the letter $e$ for the basis, even though there is no such thing as the "standard basis" in this context.
It is worth mentioning here that the fact that we can express the basis vectors as $e_{1}=(1, 0, 0, \ldots, 0)^{T}, e_{2}=(0, 1, 0, \ldots, 0)^{T},$ etc. has nothing to do with whether $e_{1}, e_{2}, \ldots$ are a "standard basis" for the given vector space or not. For example, consider $\mathbb{R}^{2}.$ Take $u_{1}$ to be the unit vector in the positive $x$-direction and $u_{2}$ to be the unit vector obtained by rotating $u_{1}$ counterclockwise $45^{\circ}$ about the origin. Then $B=\{u_{1},u_{2}\}$ is a basis for $\mathbb{R}^{2}$, which is not the standard basis for $\mathbb{R}^{2}.$ However, the coordinate vector representations of $u_{1}$ and $u_{2}$ with respect to the chosen basis $B$ are given by $u_{1}=(1,0)^{T}$ and $u_{2}=(0,1)^{T},$ because $u_{1}=1\cdot u_{1} +0\cdot u_{2}$ and $u_{2} = 0\cdot u_{1} +1\cdot u_{2}.$ If you prefer, you can add some notation to remind you that you are working with the coordinate vectors with respect to $B$; e.g., $[u_{1}]_{B}=(0,1)^{T}$ and $[u_{2}]_{B}=(0,1)^{T}.$
GJA said:
Hi Peter,
It is worth mentioning here that the fact that we can express the basis vectors as $e_{1}=(1, 0, 0, \ldots, 0)^{T}, e_{2}=(0, 1, 0, \ldots, 0)^{T},$ etc. has nothing to do with whether $e_{1}, e_{2}, \ldots$ are a "standard basis" for the given vector space or not. For example, consider $\mathbb{R}^{2}.$ Take $u_{1}$ to be the unit vector in the positive $x$-direction and $u_{2}$ to be the unit vector obtained by rotating $u_{1}$ counterclockwise $45^{\circ}$ about the origin. Then $B=\{u_{1},u_{2}\}$ is a basis for $\mathbb{R}^{2}$, which is not the standard basis for $\mathbb{R}^{2}.$ However, the coordinate vector representations of $u_{1}$ and $u_{2}$ with respect to the chosen basis $B$ are given by $u_{1}=(1,0)^{T}$ and $u_{2}=(0,1)^{T},$ because $u_{1}=1\cdot u_{1} +0\cdot u_{2}$ and $u_{2} = 0\cdot u_{1} +1\cdot u_{2}.$ If you prefer, you can add some notation to remind you that you are working with the coordinate vectors with respect to $B$; e.g., $[u_{1}]_{B}=(0,1)^{T}$ and $[u_{2}]_{B}=(0,1)^{T}.$[
Thanks for your help, GJA ... including the tip regarding Tu ...
Still reflecting on the second part of your answer ...
Peter
