Due in 10 MINUTES (Easy) (Yes/No)
  • Thread starter FAJISTE
In summary, the factors that are relevant in determining the range of a projectile launched on a large flat plain are the initial launch speed, initial launch angle, and the acceleration due to gravity on Earth. The mass and volume of the projectile do not affect the range. It is also assumed that there is no air resistance and the acceleration due to gravity is constant.
FAJISTE
57
Which of the following factors are relevant in determining the range of a projectile that is launched on a very large flat plain? (i.e. no hills or cliffs)
mass of projectile
volume of projectile
1. No, acceleration of gravity is constant, object falls at same speed with no air resistance
2. Yes, initial launch speed is necessary to calculate distance traveled, etc.
3. Yes? it is needed to calculate
4.Yes. different angles allow different ranges, 45 deg is the greatest distance on x
5. No, volume doesn't matter pretty obviousAm I correct? I have one last try
You need to show your working before we can help you.
Done. Is it right?
It depends. What are your assumptions?
woot i was right :P
FAQ: Due in 10 MINUTES (Easy) (Yes/No)
Can I extend the deadline for "Due in 10 MINUTES (Easy) (Yes/No)"?
No, the deadline cannot be extended. It is important to submit your work on time to maintain fairness and integrity in the scientific community.
Is there a penalty for submitting "Due in 10 MINUTES (Easy) (Yes/No)" late?
Yes, there may be a penalty for submitting late work. It is important to follow deadlines to demonstrate your commitment and responsibility as a scientist.
Can I collaborate with others on "Due in 10 MINUTES (Easy) (Yes/No)"?
It depends on the specific instructions for the assignment. In some cases, collaboration may be allowed, but in others, it may be considered cheating. It is best to clarify with your instructor beforehand.
Is there a specific format or template for "Due in 10 MINUTES (Easy) (Yes/No)"?
Again, this depends on the instructions for the assignment. Some assignments may require a specific format, while others may allow for more creativity. Make sure to carefully read and follow the instructions given by your instructor.
How much time should I spend on "Due in 10 MINUTES (Easy) (Yes/No)"?
The amount of time you spend on an assignment will vary depending on its difficulty level and your own skills and knowledge. It is important to start early and allocate enough time to complete the assignment to the best of your ability.
