MHB Duncan G's Questions on Implicit Diff. & Related Rates
The discussion focuses on solving problems related to implicit differentiation and related rates. The second derivative of the curve defined by x^(1/2) + y^(1/2) = 1 is found to be 1/(2x^(3/2)). For the curve x^2*y^2 + x*y = 2, the points where the slope of the tangent line is -1 are identified as (-1, -1) and (1, 1). The rate at which the distance between two ships is changing at 4:00 PM is calculated to be approximately 21.39 km/h. Lastly, the speed of the tip of a man's shadow moving away from a street light is determined to be 25/3 ft/s.
MarkFL
MHB
Here are the questions:
Related Rates and Implicit Differentiation Question? Please help!?
What is y'' (second derivative) of:
x^(1/2) + y^(1/2) = 1 ?
Find all points on the curve x^2*y^2 + x*y = 2 where the slope of the tangent line is -1.
At noon, ship A is 150 km west of ship B. Ship A is sailing east at 35 km/hr and ship is sailing north at 25 km/hr. How fast is the distance between the ships changing at 4:00 PM?
A street light is mounted at the top of a 15-ft-tall pole. A man 6 ft tall walks away from the pole with a speed of 5 ft/s along a straight path. How fast is the tip of his shadow moving when is 40 ft from the pole?
Thank you for your help.
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Duncan G,
1.) We are given the implicitly defined curve:
$$x^{\frac{1}{2}}+y^{\frac{1}{2}}=1$$
Implcitly differentiating with respect to $x$, we find:
$$\frac{1}{2}x^{-\frac{1}{2}}+\frac{1}{2}y^{-\frac{1}{2}}\frac{dy}{dx}=0$$
Solving for $$\frac{dy}{dx}$$, we obtain:
$$\frac{dy}{dx}=-\frac{y^{\frac{1}{2}}}{x^{\frac{1}{2}}}$$
Implicitly differentiating again with respect to $x$, we get:
$$\frac{d}{dx}\left(\frac{dy}{dx} \right)=-\frac{x^{\frac{1}{2}}\frac{1}{2}y^{-\frac{1}{2}}\frac{dy}{dx}-y^{\frac{1}{2}}\frac{1}{2}x^{-\frac{1}{2}}}{\left(x^{\frac{1}{2}} \right)^2}$$
Using the first derivative, and simplifying, we get:
$$\frac{d^2y}{dx^2}=\frac{1+\frac{y^{\frac{1}{2}}}{x^{\frac{1}{2}}}}{2x}$$
Multiplying by $$\frac{x^{\frac{1}{2}}}{x^{\frac{1}{2}}}$$, we have:
$$\frac{d^2y}{dx^2}=\frac{x^{\frac{1}{2}}+y^{\frac{1}{2}}}{2x^{\frac{3}{2}}}$$
Using the fact that $$x^{\frac{1}{2}}+y^{\frac{1}{2}}=1$$, we then get:
$$\frac{d^2y}{dx^2}=\frac{1}{2x^{\frac{3}{2}}}$$
We can check this result by explicitly differentiating. Let's write the original relation as:
$$y=\left(1-x^{\frac{1}{2}} \right)^2$$
$$\frac{dy}{dx}=2\left(1-x^{\frac{1}{2}} \right)\left(-\frac{1}{2}x^{-\frac{1}{2}} \right)=1-x^{-\frac{1}{2}}$$
$$\frac{d^2y}{dx^2}=\frac{1}{2}x^{-\frac{3}{2}}=\frac{1}{2x^{\frac{3}{2}}}$$
2.) We are given the implicit relation:
$$x^2y^2+xy=2$$
and asked to find the points where the slope of the tangent line is $-1$. So, implcitly differentiating with respect to $x$, we find:
$$x^2\cdot2y\frac{dy}{dx}+2xy^2+x\frac{dy}{dx}+y=0$$
Moving all terms not having $$\frac{dy}{dx}$$ as a factor to the right, we get:
$$x^2\cdot2y\frac{dy}{dx}+x\frac{dy}{dx}=-2xy^2-y$$
Factoring both sides:
$$\left(x(2xy+1) \right)\frac{dy}{dx}=-y(2xy+1)$$
Hence:
$$\frac{dy}{dx}=-\frac{y}{x}$$
Equating this slope to $-1$, we obtain:
$$y=x$$
Substituting for $y$ in the original equation, and writing in standard form, we may solve for $x$:
$$x^4+x^2-2=0$$
Factor:
$$\left(x^2+2 \right)\left(x^2-1 \right)=0$$
The first factor has imaginary roots, so we are left with:
$$x=\pm1$$
Now, since $y=x$, the two points are then:
$$(-1,-1),\,(1,1)$$
Here is a plot of the curve ant its two tangent lines with slope $-1$:
3.) Let's orient our coordinate axes such that ship A is at the origin at noon, and so ship B is at $(150,0)$. Thus, we may describe the position of each ship parametrically as follows:
Ship A:
$$x=35t$$
$$y=0$$
Ship B:
$$x=150$$
$$y=25t$$
If we let $D$ be the distance between the ships at time $t$, we may use the distance formula to write:
$$D^2(t)=(35t-150)^2+(25t)^2=50\left(37t^2-210t+450 \right)$$
Implicitly differentiating with respect to $t$, we find:
$$2D(t)D'(t)=50(74t-210)=100(37t-105)$$
Hence:
$$D'(t)=\frac{50(37t-105)}{D(t)}=\frac{\sqrt{50}(37t-105)}{\sqrt{37t^2-210t+450}}$$
At 4:00 pm, we have $t=4$, and so we find:
$$D'(4)=\frac{\sqrt{50}(37(4)-105)}{\sqrt{37(4)^2-210(4)+450}}=\frac{215}{\sqrt{101}}\,\frac{\text{km}}{\text{hr}}$$
Thus, at 4:00 pm the distance between the ships is increasing at a rate of about 21.3933 kph.
4.) Please refer to the following diagram:
$P$ is the height of the pole, $M$ is the height of the man, $D$ is the man's distance from the pole, and $x$ is the length of the shadow.
By similarity, we find:
$$\frac{D+x}{P}=\frac{x}{M}$$
$$DM+Mx=Px$$
$$x=\frac{DM}{P-M}$$
Observing that $x$ and $D$ are changing with time, we find by implcitly differentiating with respect to time $t$, we have:
$$\frac{dx}{dt}=\frac{M}{P-M}\frac{dD}{dt}$$
Also observing that movement of the tip of the man's shadow is the result not only of the shadow growing but also of the man's movement, we find that we must add these rates of change, so that the rate of change of the point $T$ of the tip of the shadow is given by:
$$\frac{dT}{dt}=\frac{dD}{dt}+\frac{dx}{dt}=\frac{dD}{dt}\left(1+\frac{M}{P-M} \right)=\frac{P}{P-M}\frac{dD}{dt}$$
Now, using the given data (did you notice we do not need $D$?):
$$P=15\text{ ft},\,M=6\text{ ft},\,\frac{dD}{dt}=5\,\frac{\text{ft}}{\text{s}}$$
We find:
$$\frac{dT}{dt}=\frac{15}{15-6}\cdot5\,\frac{\text{ft}}{\text{s}}=\frac{25}{3}\,\frac{\text{ft}}{\text{s}}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
