Duration of sound in our brain (0.1s)
In summary, our brain has the ability to remember a sound for 1/10 of a second and can distinguish between an echo and reverberation if the distance is at least 17 meters. However, if the distance is shorter, the sound may be distorted and not recognized as a separate echo. Our brain is designed to recognize patterns and utilize the most information from the sounds it receives. This is why we are able to easily recognize familiar words like "book" compared to made up words like "foons". Our brain's processing system starts early on and condenses information into understandable concepts.
fog37
1,568
108
Hello,
a certain sound remains in our brain for 1/10 of a second. The phenomenon of echo can happen only if the distance is at least 17 meters: we say the letter A, which remains in our brain for 1/10s, and the reflection (echo) of A arrives to our ear after that 0.1s...If the distance is shorter than 17 meters we get reverberation.
Aside from echo and reverberation, when we speak a whole word, like book, we clearly hear each single letter (b-o-o-k). Why doesn't the 0.1s memory of each letter play a factor? that would make each letter overlap in our brain...
A brain is not like a digital computer which manipulates data according to a linear set of instructions which execute at 'n' amount of CPU ticks per second.
It is a system which is good at recognizing patterns, and the more a pattern is re-inforced the faster a brain responds to it.
This is a very complicated subject. Our hearing does both frequency and time analysis on the sounds we receive. When a sound arrives at our ear via two different paths, There are two possible effects. A long relative delay can be distinguished as two separate sounds (an echo) and a short relative delay will result in a distinguishable change in the frequency spectrum of the sound which you can't resolve as a time difference. There is a good analogy with reception of analogue TV signals under 'multipath conditions'. Reflected signals from a distant building will produce identifiable low level delayed images, superimposed on the main picture which we actually call echos. (Football players running across a green field will each have faint a shadow, following them). Reflections from a nearby obstruction (short relative delay) are invisible (not resolved) but can cause the sound or colour information to be distorted because they sit in a part of the TV signal spectrum that's different from the coarse detail (main shapes in the picture).
Your brain evolved to get the most information out of the sounds it receives for the 'cost' of running your hearing system. Your 'memory' of a situation is formed by a complicated signal processing system (different from the DSP that we can do with computers- see rootone's comments). Was your '1/10s' figure just a rough idea?
Your example of the way the word 'book' is recognised is a bit too simplistic because that word is very familiar and you associate that sound pattern with all your other memories of books. The response to it is very different from hearing the (made up) word 'foons'. People say that 'we hear what we want to hear', and I agree. The total input of information into our brains is far too high to deal with so we have to condense it into understandable and familiar concepts. That process starts very early on in our processing systems. (The same thing happens with vision, with a lot of processing taking part on the actual surface of the retina.) No one 'designed' these systems.
FAQ: Duration of sound in our brain (0.1s)
What is the duration of sound in our brain?
The duration of sound in our brain is approximately 0.1 seconds. This means that our brain can process a sound within this time frame, allowing us to hear and interpret it.
Why does sound only last for 0.1 seconds in our brain?
This is because our brain is constantly receiving and processing new information, so it needs to quickly move on to the next sound. The 0.1 second duration allows for efficient processing of auditory information.
Does the duration of sound in our brain vary for different individuals?
Yes, the duration of sound in our brain can vary slightly from person to person. Factors such as age, hearing ability, and neurological differences can affect the speed at which our brain processes sound.
Can the duration of sound in our brain be improved?
There is currently no scientific evidence to suggest that the duration of sound in our brain can be improved. However, regular exposure to stimulating auditory experiences, such as listening to music or engaging in conversation, can help keep our brain's auditory processing sharp.
What happens if a sound lasts longer than 0.1 seconds?
If a sound lasts longer than 0.1 seconds, our brain will continue to process it until the sound ends or is replaced by a new sound. This can lead to a buildup of auditory information, which can affect our ability to accurately interpret and remember the sound.
