Dust Particle Moving with Air Drag
In summary: Your Name]In summary, Kevin is working on a particle image velocimetry system for his senior project. He is struggling with a complicated differential equation involving the velocity and displacement of a particle in a constant airflow. He has found an empirical equation for the drag coefficient, but the equation is difficult to solve. Possible approaches to solving the equation include making simplifications, using numerical methods, or seeking help from others who have worked on similar problems.
spartandfm18
Hello everyone,
This question isn't exactly a homework problem, but it's a problem I need to solve for my senior project, which is a particle image velocimetry system. I'm running into a nasty differential equation which is what I'm having trouble with.
A 30 micron diameter mica particle is placed at rest in a constant uniform airflow of (va)i +0j+0k, where va is the velocity of the oncoming air. It is allowed to accelerate to the velocity of the oncoming air. Find the velocity of the particle v as a function of the displacement of the particle x.
FD = (1/2)CDρaA(va-v)2
For Re<0.5, the drag coefficient of a sphere is almost exactly 24/Re. For higher Re, it is all over the place, and there is an empirical equation for it in my fluids book that is loosely based on 24/Re by these guys named Clift and Gauvin. Its variations are significant enough to be the difference between these particles having a terminal velocity of 18in/s and 3in/s (3in/s was determined to be the terminal velocity of one of these particles.) In the terminal velocity problem the differential equation of motion is a Bernoulli equation. After solving the differential equation I plugged in rho*v*d/mu for each occurence of the Reynolds number in the empirical formula for drag coefficient. Thus an iterative solution was found (using mathcad, you really have to wonder how people got anything done before computer algebra systems).
In other words, I think I have a decent plan for dealing with the variations in the drag coefficient. In any case it isn't part of the question, which I'm getting to.
The drag force does a certain amount of work on the particle, and that work is equivalent to the increase in its kinetic energy:
(1/2)m(v)2=∫FDcos(0)dx
The particle experiences a drag force proportional to the square of the difference between its velocity and the velocity of the oncoming air. (This makes sense, otherwise the particle would not match the speed of the air):
(1/2)m(v)2=∫ (1/2)(CDρa)A(va-v)2dx
The constants pull out of the integral and we get
(m/(CDρaA))(v)2=∫(va-v)2dx
Differentiating both sides with respect to x we get
(2m/(CDρaA))v*v'=(va-v)2
Calling the quantity (2m/(CDρaA)) k and expanding the polynomial on the right side of the equation,
k*v*v'=va2-2*v*va+v2
Dividing through by v,
k*v'=va2/v-2*va+v
Rearranging, it becomes
v'-v/k=(1/k)(va2/v-2*va)
This differential equation is a monster. It is so close to being solvable as a bernoulli equation but the term 2va makes it impossible to get into the form of a bernoulli equation.
So my question is, have any of you seen an equation like that before, and do any of you guys know how to solve it? Mathematica refuses to touch it. Thanks so much in advance.
-Kevin
Dear Kevin,
Thank you for sharing your project with us. It seems like you have a very interesting and challenging problem to solve. The differential equation you have encountered is indeed a bit complicated, but there are a few approaches you can take to solve it.
One option is to try and simplify the equation by making some assumptions or approximations. For example, you could assume that the drag coefficient is constant, or that the air velocity is much larger than the particle velocity. These simplifications may make the equation more manageable and allow you to solve it using standard methods.
Another option is to use numerical methods to solve the equation. This involves discretizing the equation and using iterative methods to approximate the solution. This approach may be more time consuming, but it can often yield accurate results.
Lastly, you could also try reaching out to other scientists or researchers who have worked on similar problems. They may have insights or techniques that could help you solve the equation.
I wish you the best of luck with your project and I hope you are able to find a solution to this challenging equation.
Related to Dust Particle Moving with Air Drag
1. What is air drag?
Air drag, also known as air resistance, is a force that opposes the motion of an object as it moves through the air. It is caused by the molecules in the air colliding with the surface of the object and slowing it down.
2. How does air drag affect the movement of dust particles?
Air drag has a significant impact on the movement of dust particles. As the particles move through the air, they experience a force of air drag in the opposite direction of their motion. This force causes the particles to slow down and eventually come to a stop.
3. What factors affect the amount of air drag on a dust particle?
The amount of air drag on a dust particle is affected by several factors, including the particle's size, shape, and speed, as well as the air density and viscosity. The larger and more irregularly shaped the particle, the greater the air drag it will experience. Additionally, the faster the particle is moving and the denser or thicker the air, the higher the air drag force will be.
4. How does the direction of air flow affect the movement of dust particles?
The direction of air flow has a significant impact on the movement of dust particles. If the air flow is in the same direction as the particle's motion, it will help to reduce the air drag force and allow the particle to move faster. However, if the air flow is in the opposite direction, it will increase the air drag force and slow down the particle's movement.
5. Can air drag be beneficial in any way for dust particles?
In some cases, air drag can be beneficial for dust particles. For example, it can help to remove dust particles from the air and prevent them from settling on surfaces. It can also play a role in the transportation of dust particles, such as in the case of wind carrying particles over long distances.
  • Mechanics
  • Classical Physics
