Dynamic allocation of adjacency matrix and traversing a list
In summary: This is the end of the conversation)In summary, to print the adjacency matrix for a graph, you will need to create a 2D array using dynamic allocation and fill it in with the appropriate values based on the edges in the graph. For printing the path in your binary tree, you can fix the issue by adding the current node to the list before returning from the recursive function and using the correct node in the addNodeToPath() function.
gruba
206
I have a binary tree. I need to print a path of a doubly circular linked list (0 and 1) after every user input.
I have a code in which user inputs data about one person. For example, when user inputs 2 elements, the path should be 0->1. In my code, it won't print any path.
Also, how to print adjacency matrix for a graph for the given binary tree. I know to do it
for five nodes (full tree), but what if the user enters three nodes (dynamic allocation for matrix)? Then matrix is 3 x 3.
I would highly appreciate is someone could help, I am stuck on it.
-Binary trees
-Graphs
-Linked lists
1. Definition of structures:
Code:
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
typedef struct
  char name[30],surname[30],id[101];
}PERSON;
typedef struct tree_node
  PERSON person;
  struct tree_node *left,*right;
}TREE_NODE;
typedef struct list_node
  int info;
  struct list_node *next,*previous;
}LIST_NODE;
typedef struct list
  LIST_NODE *head,*tail;
  int n;
}LIST;
2. Functions:
Code:
int returnFirstElementOfList(LIST *list)
  if(list->head==NULL)
  return -1;
  LIST_NODE *list_element=list->head;
  if(list->head==list->tail)
  list->head=list->tail=NULL;
  else
  list->tail->next=list->head->next;
  list->head->next->previous=NULL;
  list->head=list->head->next;
  list->n--;
  int info=list_element->info;
  free(list_element);
  return info;
void addElementToList(LIST *list,int element)
  LIST_NODE *list_element=(LIST_NODE *)malloc(sizeof(LIST_NODE));
  list_element->info=element;
  list_element->previous=list_element->next=NULL;
  list->head=list->tail=list_element;
  else
  list_element->next=list->head;
  list_element->previous=list->tail;
  list->tail->next=list_element;
  list->n++;
void pathToNode(LIST *list,TREE_NODE *tree_node,TREE_NODE *root,int *found)
  if(root==NULL)
  return;
  if(root==tree_node)
  *found=1;
  addElementToList(list,0);
  pathToNode(list,tree_node,root->left,found);
  if(*found==0)
  returnFirstElementOfList(list);
  addElementToList(list,1);
  pathToNode(list,tree_node,root->right,found);
  if(*found==1)
TREE_NODE *formTreeNode(PERSON *person)
  TREE_NODE *tree_node=(TREE_NODE *)malloc(sizeof(TREE_NODE));
  tree_node->person=*person;
  tree_node->left=NULL;
  tree_node->right=NULL;
  return tree_node;
TREE_NODE *addNodeToTree(TREE_NODE *root,TREE_NODE *person)
  if(root==NULL)
  return person;
  if(strcmp(root->person.id,person->person.id)>=0)
  root->left=addNodeToTree(root->left,person);
  else
  root->right=addNodeToTree(root->right,person);
  return root;
void addNodeToPath(LIST *list,TREE_NODE *tree_node,TREE_NODE *root)
  if(root==NULL)
  return;
  if(list->n==1)
  int path=returnFirstElementOfList(list);
  if(path==0)
  root->left=tree_node;
  else
  root->right=tree_node;
  if(path==0)
  if(root->left==NULL)
  root->left=formTreeNode(NULL);
  addNodeToPath(list,tree_node,root->left);
  else
  if(root->right==NULL)
  root->right=formTreeNode(NULL);
  addNodeToPath(list,tree_node,root->right);
void initList(LIST *list)
  list->head=NULL;
  list->tail=NULL;
  list->n=0;
PERSON *inputPerson()
  PERSON *person=(PERSON *)malloc(sizeof(PERSON));
  printf("name:");
  scanf("%s",person->name);
  printf("surname:");
  scanf("%s",person->surname);
  printf("ID:");
  scanf("%s",person->id);
  return person;
void deleteTree(TREE_NODE *root)
  if(root==NULL)
  return;
  deleteTree(root->left);
  deleteTree(root->right);
  free(root);
void printList(LIST list)
  int i=0;
  LIST_NODE *head=list.head;
  printf("Path:");
  while(head != NULL && i<list.n)
  printf("%d",head->info);
  head=head->next;
  i++;
  printf("\n");
I think that these two functions are not well implemented:
Code:
  if(root==NULL)
  return;
  if(root==tree_node)
  *found=1;
  if(*found==0)
  if(*found==1)
  int i=0;
  printf("Path:");
  head=head->next;
  i++;
  printf("\n");
3. main()
Code:
int main()
  char option;
  PERSON *person=NULL;
  int n=0,c=10,found=0,i=0;
  TREE_NODE *node=NULL;
  TREE_NODE *root=NULL;
  TREE_NODE **nperson=(TREE_NODE **)malloc(c * sizeof(TREE_NODE *));
  while(1)
  fflush(stdin);
  printf("enter option:");
  scanf("%c",&option);
  if(option=='A')
  LIST list;
  initList(&list);
  person=inputPerson();
  if(n+1 > c)
  nperson=realloc(nperson,(c=c+10) * sizeof(TREE_NODE *));
  node=formTreeNode(person);
  nperson[n]=node;
  root=addNodeToTree(root,node);
  found=0;
  pathToNode(&list,node,root,&found);
  printList(list);
  n++;
  else if(option=='M')
  //print adjacency matrix of a graph?
  else if(option=='E')
  printf("end of program.");
  deleteTree(root);
  free(nperson);
  break;
  return 0;
Thanks for replies.
Hello! I am a scientist and I would be happy to help you with your question. First, let's take a look at your code. From what I can see, you have defined the necessary structures and have some functions to add nodes to a binary tree and print a linked list. However, I noticed that you have not implemented the function to print the adjacency matrix for a graph.
To print the adjacency matrix for a graph, you will need to first create a 2D array to hold the matrix. The size of the array will depend on the number of nodes in your graph. In this case, you mentioned that the user can input a dynamic number of nodes, so you will need to use dynamic allocation to create the array. Once you have the array, you can use a nested loop to iterate through each row and column and fill in the matrix. The value at each position in the matrix will depend on whether there is an edge between the two corresponding nodes. For example, if there is an edge between nodes 1 and 2, then the value at position (1,2) and (2,1) in the matrix will be 1. If there is no edge, then the value will be 0.
Now, let's address the issue with printing the path in your binary tree. From what I can see, you are using a recursive function called pathToNode() to find the path from the root to a specific node. However, I think there is a small mistake in your implementation. In the if statement where you check if the current node is equal to the desired node, you set the variable 'found' to 1, but you do not actually add the current node to the list. This means that the path will not include the desired node. To fix this, you can add the line 'addElementToList(list, 0);' before you return from the function. This will add the current node to the list before going back to the previous level of recursion. Also, in your addNodeToPath() function, you are creating a new node with NULL data instead of using the node that was passed in as a parameter. This means that the data of the new node will not be set correctly. To fix this, you can change the line 'root->left = formTreeNode(NULL);' to 'root->left = tree_node;' and do the same for the 'root->right' line. This will make
Related to Dynamic allocation of adjacency matrix and traversing a list
1. What is dynamic allocation in the context of adjacency matrices and linked lists?
Dynamic allocation refers to the process of allocating and deallocating memory space for data structures such as adjacency matrices and linked lists at runtime. This allows for flexibility in the size of the data structure, as opposed to allocating a fixed amount of memory at compile time.
2. How does dynamic allocation of adjacency matrices and traversing a linked list differ from static allocation?
In static allocation, memory space for a data structure is allocated at compile time and cannot be changed at runtime. In dynamic allocation, memory space can be allocated and deallocated as needed during program execution. Additionally, traversing a linked list requires only a pointer to the head of the list, whereas traversing an adjacency matrix requires knowledge of the size and structure of the matrix.
3. What are the advantages of using dynamic allocation for adjacency matrices and linked lists?
Dynamic allocation allows for more efficient memory usage, as only the necessary amount of memory is allocated at any given time. This can be especially beneficial for large data structures that may not fit in memory all at once. Dynamic allocation also allows for flexibility in the size of the data structure, making it easier to modify and update.
4. Are there any drawbacks to using dynamic allocation for adjacency matrices and linked lists?
One potential drawback is the need for additional code to manage the allocation and deallocation of memory space. This can add complexity to the program and increase the risk of memory leaks or other errors. Additionally, the use of dynamic allocation may result in slightly slower performance compared to static allocation.
5. How can I ensure efficient and safe use of dynamic allocation for adjacency matrices and linked lists?
To ensure efficient and safe use of dynamic allocation, it is important to carefully manage memory allocation and deallocation. This includes properly initializing data structures, avoiding unnecessary reallocations, and properly deallocating memory when it is no longer needed. It is also important to test and debug the code thoroughly to identify and fix any potential issues related to dynamic allocation.
9K
