lizzyb
- 168
Question from Text
Gas (rho = 5.25 kg/m^3, v = 2.0 x 10^-5 m^2/s) is flowing in a 20-mm-diameter pipe. When a gas flowmeter measures the flow as being 0.064 kg/s, it registers a pressure drop of 8.5 kPa. Investigators plan to test an enlarged model that is geometrically similar in a 180-mm-diameter pipe.
(a) What flow rate at 25 'C water will achieve dynamic similarity?
(b) What would the pressure drop across the water meter be?
Relevant Equations/Info
When T=25'c, H2O: rho = 997.0 kg/m^3 ; v = 0.893 x 10^-6 m^2/s.
R = F_I/F_V
The book gives a table of "flow characteristics and similitude scale ratios (ratio of prototype quantity to model quantity)"; for answering (a), I'll use the one for Mass and Time:
Dimension M: (L^3 rho)_r
Dimension T: (L^2 rho / mu)_r
Work done thus far
So I'm wondering if I'm using the table correctly:
(M/T)_r = (L^3 rho)_r / (L^2 rho / mu)_r = (L mu)_r
expanding:
Flow_p / Flow_m = (L_p mu_p) / (L_m mu_m)
so
Flow_p = (L_p mu_p Flow_m) / (L_m mu_m) = (.18 * [997.0 * 0.893 x 10^-6] * 0.064) / (.02 * [ 5.25 * 2.0 x 10^-5 ]) = 4.88 kg/s.
I don't have an answer so I'm not sure if this is the correct. Does it look okay to you?
Would I do (b) similarly? That is, just use the table in like manner? Thank you.
R = F_I/F_V
Work done thus far
expanding:
so
